[mapguide-users] MapGuide Server and MapGuide Server Extensions on one Maschine
Dave Wilson dave.wilson at autodesk.com
Thu Aug 13 13:42:57 EDT 2009
Often times the startup of Windows gets slower as you add more things to it.
A well defragged drive often helps eliminate this problem.
I use Defraggler and after the initial defrag I will often defrag several more times to ensure the file are optimized. It really can make a difference on the startup performance. Windows Defrag will only really do it once or twice, but the results are not the same.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Thomasch
Sent: Thursday, August 13, 2009 9:34 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Server and MapGuide Server Extensions on one Maschine
Thanks Trevor,
it turned out that the MapGuide Service didn't start beause of an
timeout. Seems to be an Windows Issue - I started the Service manually
and everything is ok.
Thanks,
Thomasch
Trevor Wekel wrote:
> Hi Thomasch,
> Does restarting the MapGuide Server service and/or IIS correct the problem?  Is there a firewall blocking the MapGuide Server process?  "netstat -ano" should show the MapGuide Server process running on 2800/2801/2802 or 2810/2811/2812 depending on the MapGuide version.
> Thanks,
> Trevor
> Sent: August 12, 2009 1:22 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MapGuide Server and MapGuide Server Extensions on one Maschine
> Hi,
> I'm trying to run MapGuide Server and MapGuide Server Extensions on one
> Maschine. After installing, every thing works fine - until reboot.
> For some reason I can't get a connection from the Webserver Extension to
> the MapGuide Server after reboot the maschine.
> Reinstalling the Server "solves" the Problem - til next reboot.
> Any sugesstions?
> Thomasch
> WinXP Home with all servicepacks,
> MapGuide 2.0.2
> mapguide-users mailing list
