[mapguide-users] Raster (SID / TIF ) Images not working !
Jason Birch Jason.Birch at nanaimo.ca
Fri Aug 14 11:33:16 EDT 2009
Your problem is likely different.
For MGOS, you can not use Studio to load rasters into MapGuide.  You must upload your rasters to the server on your own, and then use MapGuide Maestro (make sure to grab the latest preview release) to create a new data connection to them.  Try with a TIFF first, since they shouldn't require any special plug-ins.  Once you have loaded your raster, you will likely have to define a coordinate system override for it, and make sure that it matches the coordinate system of your map.
Jason
-----Original Message-----
Sent: Friday, August 14, 2009 8:17 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Raster (SID / TIF ) Images not working !
It sounds like I am having the same exact problem.  I am using Open Source
2.0.2 along with 2009 Studio.  I cannot get mrsid or tif files to load.  I
have copied the dll's and still no luck.  Did you ever get yours working?
