[mapguide-users] Change order of fields displayed in properties
pane?
Bernhard Maehler
bernhard.maehler at gmx.de
Mon Aug 17 14:46:31 EDT 2009
we are using MGE 2010 with Studio (German Version) and solved this problem by
adding
HTML comments to the "Name" column:
http://n2.nabble.com/file/n3461235/order.jpg
It works with Ajax Viewer and Fusion.
You can also add styles (see screenshot).
Bernhard
Jo Cook wrote:
> Hi Jackie,
> That did the trick, thanks.
> Jo
> Jackie Ng wrote:
>> The properties are sorted before being displayed in the properties pane.
>> You could try commenting out or removing the following line of code to
>> see how things go.
>> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ#L2837
>> - Jackie
>> Jo Cook wrote:
>>> Dear All,
>>> Is it possible to specify the order in which fields are displayed in the
>>> properties pane? Currently it seems to display them in alphabetical
>>> order, rather than the order in which they appear in the data source.
>>> The only way I can think of getting round it at the moment is to number
>>> all of the properties, which will look a bit strange...
>>> Thanks
>>> Jo
View this message in context: http://n2.nabble.com/Change-order-of-fields-displayed-in-properties-pane--tp3438480p3461235.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090817/45966ba1/attachment.html
