[mapguide-users] Converting dwg into shp
James H. Murphy jhm at alacad.com
Fri Aug 28 16:08:58 EDT 2009
You can create some mapexport profiles and save them while you export
one dwg, then use those export profiles in a script to export with out
having to enter all the parameters for each export. Also look here for
the ScriptPro app that may help with running the scripts.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkI
D=9240618
James Murphy
Geospatial Solutions Specialist
ALACAD
(205) 444-3100
www.alacad.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Thomasch
Sent: August 28, 2009 2:00 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Converting dwg into shp
is there a way to convert dwg into shp in a batch? I've got some
drawings with many layers and would like to have at least one shp per
layer. I tried Autodesk Map - which is pretty good, but there i din't
find any batch mode.
Thanks
Thomasch
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
