[mapguide-users] mapguide server crashs even for 5 users
balaji bitra bitbalaji at gmail.com
Thu Dec 3 04:50:08 EST 2009
hi
i already install MGOS 2.1 but the application is not working which is
working on mgos 2.0 and throws error "OSGEO.MAPGUIDE" NAMESPACE error.
thanks
balaji
Jason Birch wrote:
> I would recommend trying with MapGuide 2.1.  I was having similar problems
> with 2.0.x that almost completely derailed my implementation, though I
> don't
> recall that exact error message.
> http://download.osgeo.org/mapguide/releases/2.1.0/MapGuideOpenSource-2.1.0.4283-Final.exe
> This build was just uploaded last night and has not been thoroughly
> tested,
> but unless I did something wrong when building the installer it will be
> the
> official 2.1 release.
> As mentioned, you will also need to use something other than XP for load
> testing; no idea what the behaviour is when the OS starts denying
> connections, but it could easily be the cause of this kind of problem.
> Jason
> 2009/11/18 sathishpsk9 <>
>> Both Library://thematic/layout.WebLayout  (for thematic viewing  )
>> and Library://proptax/layout.WebLayout exist( info search )
>> Initially 3 users are accesing the application , and each user is working
>> with a different layout.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/mapguide-server-crashs-even-for-5-users-tp4024330p4105093.html
