[mapguide-users] MGOS 2.1 - One(1) good Two(2) bad
Jason Birch
jason at jasonbirch.com
Sun Dec 6 00:08:48 EST 2009
Can you provide me with a place to download one of the orthos (email
me directly) and if possible small shp/sdf in same area.
Also, it would be great if you could put this detail into an existing
ticket; Trevor indicated that he may be able to find time to look at
this so the more data the better.
Do you have access to fme?
Jason
On 2009-12-05, djonio <DJonio at miami-airport.com> wrote:
> All of the XML retrieval was done w/Maestro. It looks like you hit the nail
> on the head Jason. The FdoSpatialContextList retrieval is hosed up for my
> MrSIDS. Since FDO and/or GDAL16 are not even close as to getting it correct
> on the input side I cannot see how it is going to get right on the output
> side.
> I have included the XML from 2.0.2 and 2.1 below along w/the obvious server
> stuff that seems to say GDAL is installed and configured correctly ... sucks
> to be me :-(
> r,
> dennis
> ##### MAPGUIDE ERROR LOG:
> <2009-12-05T16:37:03> 5816
> Success: Server stopped.
> <2009-12-05T16:42:14> 852
> Success: Server started.
> <2009-12-05T17:13:23> 5652 Ajax Viewer 10.14.X.XX Administrator
> Error: Failed to stylize layer: Aerial2008SP
> The coordinate system initialization failed.
> Could not initialize the geodetic transformation.
> StackTrace:
> - MgMappingUtil.StylizeLayers() line 776 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\mapping\MappingUtil.cpp
> ##### MAPGUIDE server runtime
> w/CPL_DEBUG:
> C:\Program Files\OSGeo\MapGuide\Server\bin>mgserver run
> Running the server interactively as an application instead of as a service.
> (852) Server starting...
> (852) Mentor Coordinate System Library
> (852) Server started.
> GDAL: Auto register C:\Program
> Files\OSGeo\MapGuide\Server\bin\gdalplugins\gdal_ECW_JP2ECW.dll using
> GDALRegister_ECW_JP2ECW.
> Files\OSGeo\MapGuide\Server\bin\gdalplugins\gdal_MrSID.dll using
> GDALRegister_MrSID.
> GDALRegister_MrSID.
> ##### XML from MGOS 2.0.2 -
> <?xml version="1.0"?>
> <FdoSpatialContextList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FdoSpatialContextList-1.0.0.xsd">
> <ProviderName>OSGeo.Gdal.3.3</ProviderName>
> <SpatialContext IsActive="true">
> <Name>NAD83(HARN) / Florida East (ftUS)</Name>
> <Description>This coordinate system has been overridden.</Description>
> <CoordinateSystemName>PROJCS["FL83-EF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999941176471],PARAMETER["central_meridian",-81.00000000000000],PARAMETER["latitude_of_origin",24.33333333333333],UNIT["Foot_US",0.30480060960122]]</CoordinateSystemName>
> <CoordinateSystemWkt>PROJCS["FL83-EF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999941176471],PARAMETER["central_meridian",-81.00000000000000],PARAMETER["latitude_of_origin",24.33333333333333],UNIT["Foot_US",0.30480060960122]]</CoordinateSystemWkt>
> <ExtentType>Dynamic</ExtentType>
> <Extent>
> <LowerLeftCoordinate>
> <X>877070.59535700001</X>
> <Y>524581.66131</Y>
> </LowerLeftCoordinate>
> <UpperRightCoordinate>
> <X>902690.59535700001</X>
> <Y>539301.66131</Y>
> </UpperRightCoordinate>
> </Extent>
> <XYTolerance>0</XYTolerance>
> <ZTolerance>0</ZTolerance>
> </SpatialContext>
> </FdoSpatialContextList>
> FeatureSource
> <?xml version="1.0" encoding="utf-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> <Provider>OSGeo.Gdal</Provider>
> <Parameter>
> <Name>DefaultRasterFileLocation</Name>
> <Value> C:\OSGeoData\MIA\Aerial200SP </Value>
> </Parameter>
> <SupplementalSpatialContextInfo>
> <CoordinateSystem>PROJCS["FL83-EF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999941176471],PARAMETER["central_meridian",-81.00000000000000],PARAMETER["latitude_of_origin",24.33333333333333],UNIT["Foot_US",0.30480060960122]]</CoordinateSystem>
> </SupplementalSpatialContextInfo>
> </FeatureSource>
> ##### XML from MGOS 2.1 -
> <ProviderName>OSGeo.Gdal.3.4</ProviderName>
> <Name>Default</Name>
> <Description>System generated default FDO Spatial Context</Description>
> <CoordinateSystemName>Default</CoordinateSystemName>
> <CoordinateSystemWkt>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystemWkt>
> <ExtentType>Static</ExtentType>
> <Extent>
> <X>-10000000</X>
> <Y>-10000000</Y>
> <X>10000000</X>
> <Y>10000000</Y>
> </Extent>
> <XYTolerance>0.001</XYTolerance>
> <ZTolerance>0.001</ZTolerance>
> </SpatialContext>
> FeatureSource
> <Parameter>
> <Value>C:\OSGeoData\MIA\Aerial200SP</Value>
> </Parameter>
> </FeatureSource>
> http://n2.nabble.com/MGOS-2-1-One-1-good-Two-2-bad-tp4114766p4119526.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
