[mapguide-users] Connection Problem
Zac Spitzer
zac.spitzer at gmail.com
Mon Dec 7 02:05:38 EST 2009
ok, can you install the firebox addon and enable the net tab,
often is can be a missing file, which should show up in red
under the net tab
z
2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in>
> I tried it on Firefox
> It is showing the following error on the console:
> Error: parent.parent.mapFrame is undefined
> Source File:
> http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
> Line: 25
> Rest of them are warnings.
> I am attaching the ScreenShot as well.
> Thanks and Regards.
> --- On *Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com>* wrote:
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Subject: Re: [mapguide-users] Connection Problem
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Monday, 7 December, 2009, 11:25 AM
> 302 is a just a redirect, not an error, so I wouldn't worry so much about
> that
> I note you mentioned using IE, does using Firefox make any difference?
> Anything show up in the firefox error console?
> z
> 2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>> When I try the link
>> http://192.168.224.24:8008/mapguide/javasamples/main.jsp
>> from the machine with ip 192.168.224.135 it is giving the error ( IE
>> cannot display the webpage)
>> it gives only 3 entries in the access log of apache installed on my
>> machine with ip 192.168.224.24
>> Following are the entries:
>> 192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET
>> /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
>> /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
>> /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
>> HTTP/1.1" 302 472
>> But When I try the link http://192.168.224.24
>> :8008/mapguide/javasamples/main.jsp<http://:8008/mapguide/javasamples/main.jsp>
>> from my machine it is creating lot of entries in the access log of apache.
>> Comparing the entries is not helping the cause.
>> I could not figure out where the problem is?
>> Plz help!!!
>> Thanks and Regards.
>> --- On *Fri, 4/12/09, manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>> >* wrote:
>> From: manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org<http://in.mc941.mail.yahoo.com/mc/compose?to=mapguide-users@lists.osgeo.org>
>> Date: Friday, 4 December, 2009, 4:43 PM
>> There is an entry in the access logs of apache which says:
>> 192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET
>> /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=
>> *Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout HTTP/1.1" 302
>> 489*
>> How can I resolve this status code 302 error.
>> Googling hasn't helped.
>> *I haven't found any relevant entry in the Logs of Tomcat and MGOS 2.0.*
>> Still stuck!!
>> I am in my learning stage Zac.
>> Pardon me.
>> Thanks for all the help!!
>> Regards.
>> --- On *Fri, 4/12/09, Zac Spitzer <zac.spitzer at gmail.com<http://in.mc941.mail.yahoo.com/mc/compose?to=zac.spitzer@gmail.com>
>> >* wrote:
>> From: Zac Spitzer <zac.spitzer at gmail.com<http://in.mc941.mail.yahoo.com/mc/compose?to=zac.spitzer@gmail.com>
>> Date: Friday, 4 December, 2009, 10:45 AM
>> time for you to do some debugging, if your using the java samples,
>> I'd assume you know a bit about programming jsp
>> there are error logs from both your webserver, servlet container
>> 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>>> Oops! This link appears to be broken.
>>> is the error I am getting Zac.
>>> The link *http://ip:8008/mapguide/* is working fine.
>>> and showing the list of the directories.
>>> But when I try the link *http://ip:8008/mapguide/javasamples/main.jsp*
>>> is giving the above error.
>>> Help!!
>>> Date: Friday, 4 December, 2009, 9:44 AM
>>> how about a little more detail that just saying it 'errors' ?
>>> 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in<http://mc/compose?to=manav_dayal85@yahoo.co.in>
>>>> Hi everyone.
>>>> I am stuck with this.
>>>> Plz help!!
>>>> Thanks in advance.
>>>> Regards.
>>>> --- On *Thu, 3/12/09, manav dayal <manav_dayal85 at yahoo.co.in<http://mc/compose?to=manav_dayal85@yahoo.co.in>
>>>> >* wrote:
>>>> From: manav dayal <manav_dayal85 at yahoo.co.in<http://mc/compose?to=manav_dayal85@yahoo.co.in>
>>>> Subject: [mapguide-users] Connection Problem
>>>> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org<http://mc/compose?to=mapguide-users@lists.osgeo.org>
>>>> Date: Thursday, 3 December, 2009, 6:08 PM
>>>> I have MGOS 2.0 installed on my machine and my sample application is
>>>> running fine
>>>> on my machine using apache and tomcat.
>>>> When I try to access the same application from another machine by
>>>> providing the
>>>> IP Address of the my machine in the url
>>>> it gives link broken type of errors.
>>>> http://ip/ gives a page which shows *It works!*
>>>> even
>>>> http://ip/mapguide/ shows the *listing of the directories.*
>>>> but when i try to access
>>>> http://ip/mapguide/javasamples/main.jsp
>>>> it gives errors but works on my machine.
>>>> can anyone help!!!
>>>> Thanks and Regards.
>>>> The INTERNET now has a personality. YOURS! See your Yahoo! Homepage<http://in.rd.yahoo.com/tagline_yyi_1/*http://in.yahoo.com/>
>>>> -----Inline Attachment Follows-----
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091207/73c129af/attachment.html
