[mapguide-users] Connection Problem
Jason Birch
jason at jasonbirch.com
Tue Dec 8 01:04:14 EST 2009
Use something like fiddler2 to figure out what its trying to redirect
you to. Maybe a host name or ip that is unreachable from your client.
On 2009-12-07, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> 192.168.224.135 - - [08/Dec/2009:11:00:58 +0530] "GET
> /mapguide/mapviewerajax/?SESSION=ca1ee218-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
> HTTP/1.1" 302 472
> This is the 3rd entry in the access log of apache.
> All further entries are missing.
> Where can I find the file to which this 302 redirection is taking place
> I have ran out of options to resolve the issue.
> Desperately seeking help!!
> Thanks and Regards.
> --- On Mon, 7/12/09, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> From: manav dayal <manav_dayal85 at yahoo.co.in>
> Subject: Re: [mapguide-users] Connection Problem
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Monday, 7 December, 2009, 1:06 PM
> Zac
> I am unable to view any map using different machine.
> Thanks and Regards.
> --- On Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Date: Monday, 7 December, 2009, 12:42 PM
> looking at yourscreenshot again, it appears the problem is the sample code
> is hardwired to refer to
> localhost:8008 hence the problem...
> can you view a normal map without using the javasamples from another
> machine?
> 2009/12/7 Zac Spitzer <zac.spitzer at gmail.com>
> ok, can you install the firebox addon and enable the net tab,
> often is can be a missing file, which should show up in red
> under the net tab
> z
> 2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in>
> I tried it on Firefox
> It is showing the following error on the console:
> Error: parent.parent.mapFrame is undefined
> Source File:
> http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
> Line: 25
> Rest of them are warnings.
> I am attaching the ScreenShot as well.
> Thanks and Regards.
> Date: Monday, 7 December, 2009, 11:25 AM
> 302 is a just a redirect, not an error, so I wouldn't worry so much about
> that
> I note you mentioned using IE, does using Firefox make any difference?
> Anything show up in the firefox error console?
> z
> When I try the link
> http://192.168.224.24:8008/mapguide/javasamples/main.jsp
> from the machine with ip 192.168.224.135 it is giving the error ( IE cannot
> display the webpage)
> it gives only 3 entries in the access log of apache installed on my machine
> with ip 192.168.224.24
> Following are the entries:
> 192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET
> /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
> /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
> /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
> HTTP/1.1" 302 472
> But When I try the link
> from my machine it is creating lot of entries in the access log of apache.
> Comparing the entries is not helping the cause.
> I could not figure out where the problem is?
> Plz help!!!
> Thanks and Regards.
> Date: Friday, 4 December, 2009, 4:43 PM
> There is an entry in the access logs of apache which says:
> 192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET
> /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout
> HTTP/1.1" 302 489
> How can I resolve this status code 302 error.
> Googling hasn't helped.
> I haven't found any relevant entry in the Logs of Tomcat and MGOS 2.0.
> Still stuck!!
> I am in my learning stage Zac.
> Pardon me.
> Thanks for all the help!!
> Regards.
> Date: Friday, 4 December, 2009, 10:45 AM
> time for you to do some debugging, if your using the java samples,
> I'd assume you know a bit about programming jsp
> there are error logs from both your webserver, servlet container
> 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in>
> Oops! This link appears to be broken.
> is the error I am getting Zac.
> The link http://ip:8008/mapguide/ is working fine.
> and showing the list of the directories.
> But when I try the link http://ip:8008/mapguide/javasamples/main.jsp
> is giving the above error.
> Help!!
> Date: Friday, 4 December, 2009, 9:44 AM
> how about a little more detail that just saying it 'errors' ?
> Hi everyone.
> I am stuck with this.
> Plz help!!
> Thanks in advance.
> Regards.
> Subject: [mapguide-users] Connection Problem
> Date: Thursday, 3 December, 2009, 6:08 PM
> I have MGOS 2.0 installed on my machine and my sample application is running
> fine
> on my machine using apache and tomcat.
> When I try to access the same application from another machine by providing
> the
> IP Address of the my machine in the url
> it gives link broken type of errors.
> http://ip/ gives a page which shows It works!
> even
> http://ip/mapguide/ shows the listing of the directories.
> but when i try to access
> http://ip/mapguide/javasamples/main.jsp
> it gives errors but works on my machine.
> can anyone help!!!
> Thanks and Regards.
> The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
> -----Inline Attachment Follows-----
> mapguide-users mailing list
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> http://in.yahoo.com/
