[mapguide-users] Connection Problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Dec 8 03:03:37 EST 2009
There should be a redirect in your apache setup that redirects:
/mapguide/mapviewerajax/
to
/mapguide/mapviewerjava/ajaxviewer.jsp
For some reason the redirect appears to throw in "localhost".
If it is non-obvious from looking at your apache config where this is,
you may have some url-rewriting module or other item installed.
Try locating any "localhost" items in the apache config.
Alternatively, see if this is the method used:
http://webdesign.about.com/od/htaccess/ht/ht302redirect.htm
Regards, Kenneth Skovhede, GEOGRAF A/S
manav dayal skrev:
> Jason Sir,
> I tried to access the page using Firefox with firebug
> It is showing an error in the script tag which says:
> Failed to load source for sourceFile top-level
> about:neterror?e=connectionFailure&u=http%3A//localhost%3A8008/mapguide/mapviewerjava/ajaxviewer.jsp%3FSESSION%3D0b920dc6-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA%26WEBLAYOUT%3DLibrary%3A//Samples/ms/Layouts/ms.WebLayout&c=UTF-8&d=Firefox%20can%27t%20establish%20a%20connection%20to%20the%20server%20at%20localhost%3A8008.
> script.tags( X| 220 221 222 223 224 225 226 227 )
> Is this call hardwired to refer localhost?
> Can I modify it in the file /mapguide/mapviewerajax ?
> Thanks and Regards
> --- On *Tue, 8/12/09, Jason Birch /<jason at jasonbirch.com>/* wrote:
> From: Jason Birch <jason at jasonbirch.com>
> Subject: Re: [mapguide-users] Connection Problem
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Tuesday, 8 December, 2009, 11:34 AM
> Use something like fiddler2 to figure out what its trying to redirect
> you to. Maybe a host name or ip that is unreachable from your client.
> On 2009-12-07, manav dayal <manav_dayal85 at yahoo.co.in
> </mc/compose?to=manav_dayal85 at yahoo.co.in>> wrote:
> > 192.168.224.135 - - [08/Dec/2009:11:00:58 +0530] "GET
> /mapguide/mapviewerajax/?SESSION=ca1ee218-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
> > HTTP/1.1" 302 472
> > This is the 3rd entry in the access log of apache.
> > All further entries are missing.
> > Where can I find the file to which this 302 redirection is
> taking place
> > I have ran out of options to resolve the issue.
> > Desperately seeking help!!
> > Thanks and Regards.
> > --- On Mon, 7/12/09, manav dayal <manav_dayal85 at yahoo.co.in
> > From: manav dayal <manav_dayal85 at yahoo.co.in
> </mc/compose?to=mapguide-users at lists.osgeo.org>>
> > Date: Monday, 7 December, 2009, 1:06 PM
> > Zac
> > I am unable to view any map using different machine.
> > Thanks and Regards.
> > --- On Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com
> </mc/compose?to=zac.spitzer at gmail.com>> wrote:
> > From: Zac Spitzer <zac.spitzer at gmail.com
> > Date: Monday, 7 December, 2009, 12:42 PM
> > looking at yourscreenshot again, it appears the problem is the
> sample code
> > is hardwired to refer to
> > localhost:8008 hence the problem...
> > can you view a normal map without using the javasamples from another
> > machine?
> > 2009/12/7 Zac Spitzer <zac.spitzer at gmail.com
> > ok, can you install the firebox addon and enable the net tab,
> > often is can be a missing file, which should show up in red
> > under the net tab
> > z
> > 2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in
> > I tried it on Firefox
> > It is showing the following error on the console:
> > Error: parent.parent.mapFrame is undefined
> > Source File:
> http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
> > Line: 25
> > Rest of them are warnings.
> > I am attaching the ScreenShot as well.
> > Thanks and Regards.
> > Date: Monday, 7 December, 2009, 11:25 AM
> > 302 is a just a redirect, not an error, so I wouldn't worry so
> much about
> > that
> > I note you mentioned using IE, does using Firefox make any
> difference?
> > Anything show up in the firefox error console?
> > z
> > When I try the link
> > http://192.168.224.24:8008/mapguide/javasamples/main.jsp
> > from the machine with ip 192.168.224.135 it is giving the error
> ( IE cannot
> > display the webpage)
> > it gives only 3 entries in the access log of apache installed on
> my machine
> > with ip 192.168.224.24
> > Following are the entries:
> > 192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET
> > /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
> > /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
> /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
> > HTTP/1.1" 302 472
> > But When I try the link
> > from my machine it is creating lot of entries in the access log
> of apache.
> > Comparing the entries is not helping the cause.
> > I could not figure out where the problem is?
> > Plz help!!!
> > Thanks and Regards.
> > --- On Fri, 4/12/09, manav dayal <manav_dayal85 at yahoo.co.in
> > Date: Friday, 4 December, 2009, 4:43 PM
> > There is an entry in the access logs of apache which says:
> > 192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET
> /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout
> > HTTP/1.1" 302 489
> > How can I resolve this status code 302 error.
> > Googling hasn't helped.
> > I haven't found any relevant entry in the Logs of Tomcat and
> MGOS 2.0.
> > Still stuck!!
> > I am in my learning stage Zac.
> > Pardon me.
> > Thanks for all the help!!
> > Regards.
> > --- On Fri, 4/12/09, Zac Spitzer <zac.spitzer at gmail.com
> > Date: Friday, 4 December, 2009, 10:45 AM
> > time for you to do some debugging, if your using the java samples,
> > I'd assume you know a bit about programming jsp
> > there are error logs from both your webserver, servlet container
> > 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in
> > Oops! This link appears to be broken.
> > is the error I am getting Zac.
> > The link http://ip:8008/mapguide/ is working fine.
> > and showing the list of the directories.
> > But when I try the link http://ip:8008/mapguide/javasamples/main.jsp
> > is giving the above error.
> > Help!!
> > Date: Friday, 4 December, 2009, 9:44 AM
> > how about a little more detail that just saying it 'errors' ?
> > Hi everyone.
> > I am stuck with this.
> > Plz help!!
> > Thanks in advance.
> > Regards.
> > --- On Thu, 3/12/09, manav dayal <manav_dayal85 at yahoo.co.in
> > Subject: [mapguide-users] Connection Problem
> > Date: Thursday, 3 December, 2009, 6:08 PM
> > I have MGOS 2.0 installed on my machine and my sample
> application is running
> > fine
> > on my machine using apache and tomcat.
> > When I try to access the same application from another machine
> by providing
> > the
> > IP Address of the my machine in the url
> > it gives link broken type of errors.
> > http://ip/ <http://ip/%C2%A0%C2%A0> gives a page which shows
> It works!
> > even
> > http://ip/mapguide/ <http://ip/mapguide/%C2%A0> shows the
> listing of the directories.
> > but when i try to access
> > http://ip/mapguide/javasamples/main.jsp
> > it gives errors but works on my machine.
> > can anyone help!!!
> > Thanks and Regards.
> > The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
> > -----Inline Attachment Follows-----
> > mapguide-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Zac Spitzer
> > Solution Architect / Director
> > Ennoble Consultancy Australia
> > http://www.ennoble.com.au
> > http://zacster.blogspot.com
> > +61 405 847 168
> > Zac Spitzer
> > +61 405 847 168
> > Zac Spitzer
> > +61 405 847 168
> > Zac Spitzer
> > +61 405 847 168
> > Zac Spitzer
> > +61 405 847 168
> Homepage.
> > http://in.yahoo.com/
> <http://in.rd.yahoo.com/tagline_yyi_1/*http://in.yahoo.com/>.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091208/9b996eab/attachment.html
