[mapguide-users] Cannot select featuer on map with king.oracle
Zac Spitzer
zac.spitzer at gmail.com
Tue Dec 8 05:59:45 EST 2009
opening and saving the feature source will also flush the connection cache
2009/12/8 Simon Pelicon <simon at sl-king.com>:
> Hi!
> Check if table has primary key defined. If not create primary key and
> restart mgserver.
> Simon
> On Tue, Dec 8, 2009 at 11:18 AM, balaji bitra <bitbalaji at gmail.com> wrote:
>> hi Deval,
>> when you create package, did you check the "features on layer are
>> selectable" is checked in map file.
>> http://n2.nabble.com/file/n4131574/feature.bmp
>> try it!
>> balaji
>> Balaji
>> View this message in context:
>> http://n2.nabble.com/Cannot-select-featuer-on-map-with-king-oracle-tp4130603p4131574.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
