[mapguide-users] Connection Problem
manav dayal manav_dayal85 at yahoo.co.in
Tue Dec 8 23:16:05 EST 2009
Some configuration settings I did to fix this issue are as follows:-
File httpd.conf in the conf directory of apache contains the following two lines:
Redirect /mapguide/mapviewerajax/ http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp
Redirect /mapguide/mapviewerdwf/ http://localhost:8008/mapguide/mapviewerjava/dwfviewer.jsp
When http server apache redirects the browser to this url, then request is local to the machine from where the browser is requesting. Thus there are only 3 entries in the logs of the  http server
i.e till the redirect 302.
The browser never came back with the request so no further entries.
If we put the ip address of the http server instead of the localhost then the browser will
come back with the fresh request and hence forth everything will work fine.
Thanks and Regards
--- On Tue, 8/12/09, Zac Spitzer <zac.spitzer at gmail.com> wrote:
Subject: Re: [mapguide-users] Connection Problem
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Date: Tuesday, 8 December, 2009, 3:14 PM
great news, can you describe the fix?
2009/12/8 manav dayal <manav_dayal85 at yahoo.co.in>
Issue is resolved.
Thanks from the bottom of my heart to Kenneth, Jason and Zac.
You people are great.
Regards
--- On Tue, 8/12/09, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk> wrote:
From: Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
Date: Tuesday, 8 December, 2009, 1:33 PM
There should be a redirect in your apache setup that redirects:
to
For some reason the redirect appears to throw in "localhost".
If it is non-obvious from looking at your apache config where this is,
you may have some url-rewriting module or other item installed.
Try locating any "localhost" items in the apache config.
Alternatively, see if this is the method used:
http://webdesign.about.com/od/htaccess/ht/ht302redirect.htm
Regards, Kenneth Skovhede, GEOGRAF A/S
manav dayal skrev:
Jason Sir,
I tried to access the page using Firefox with firebug
It is showing an error in the script tag which says:
Failed to load source for sourceFile top-level about:neterror?e=connectionFailure&u=http%3A//localhost%3A8008/mapguide/mapviewerjava/ajaxviewer.jsp%3FSESSION%3D0b920dc6-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA%26WEBLAYOUT%3DLibrary%3A//Samples/ms/Layouts/ms.WebLayout&c=UTF-8&d=Firefox%20can%27t%20establish%20a%20connection%20to%20the%20server%20at%20localhost%3A8008. script.tags( X| 220 221 222 223 224 225 226 227 )
Is this call hardwired to refer localhost?
Can I modify it in the file /mapguide/mapviewerajax ?
Thanks and Regards
Date: Tuesday, 8 December, 2009, 11:34 AM
Use something like fiddler2 to figure out what its trying to redirect
you to. Maybe a host name or ip that is unreachable from your client.
On 2009-12-07, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> 192.168.224.135 - - [08/Dec/2009:11:00:58 +0530] "GET
> /mapguide/mapviewerajax/?SESSION=ca1ee218-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
> HTTP/1.1" 302 472
> This is the 3rd entry in the access log of apache.
> All further entries are missing.
> Where can I find the file to which this 302 redirection is taking place
> I have ran out of options to resolve the issue.
> Desperately seeking help!!
> Thanks and Regards.
> --- On Mon, 7/12/09, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> From: manav dayal <manav_dayal85 at yahoo.co.in>
> Date: Monday, 7 December, 2009, 1:06 PM
> Zac
> I am unable to view any map using different machine.
> Thanks and Regards.
> --- On Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Date: Monday, 7 December, 2009, 12:42 PM
> looking at yourscreenshot again, it appears the problem is the sample code
> is hardwired to refer to
> localhost:8008 hence the problem...
> can you view a normal map without using the javasamples from another
> machine?
> 2009/12/7 Zac Spitzer <zac.spitzer at gmail.com>
> ok, can you install the firebox addon and enable the net tab,
> often is can be a missing file, which should show up in red
> under the net tab
> z
> 2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in>
> I tried it on Firefox
> It is showing the following error on the console:
> Error: parent.parent.mapFrame is undefined
> Source File:
> http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
> Line: 25
> Rest of them are warnings.
> I am attaching the ScreenShot as well.
> Thanks and Regards.
> Date: Monday, 7 December, 2009, 11:25 AM
> 302 is a just a redirect, not an error, so I wouldn't worry so much about
> that
> I note you mentioned using IE, does using Firefox make any difference?
> Anything show up in the firefox error console?
> z
> When I try the link
> http://192.168.224.24:8008/mapguide/javasamples/main.jsp
> from the machine with ip 192.168.224.135 it is giving the error ( IE cannot
> display the webpage)
> it gives only 3 entries in the access log of apache installed on my machine
> with ip 192.168.224.24
> Following are the entries:
> 192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET
> /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
> /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
> /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
> HTTP/1.1" 302 472
> But When I try the link
> from my machine it is creating lot of entries in the access log of apache.
> Comparing the entries is not helping the cause.
> I could not figure out where the problem is?
> Plz help!!!
> Thanks and Regards.
> Date: Friday, 4 December, 2009, 4:43 PM
> There is an entry in the access logs of apache which says:
> 192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET
> /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout
> HTTP/1.1" 302 489
> How can I resolve this status code 302  error.
> Googling hasn't helped.
> I haven't found any relevant entry in the Logs of  Tomcat and MGOS 2.0.
> Still stuck!!
> I am in my learning stage Zac.
> Pardon me.
> Thanks for all the help!!
> Regards.
> Date: Friday, 4 December, 2009, 10:45 AM
> time for you to do some debugging, if your using the java samples,
> I'd assume you know a bit about programming jsp
> there are error logs from both your webserver, servlet container
> 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in>
> Oops! This link appears to be broken.
> is the error I am getting Zac.
> The link  http://ip:8008/mapguide/  is working fine.
> and showing the list of the directories.
> But when I try the link http://ip:8008/mapguide/javasamples/main.jsp
> is giving the above error.
> Help!!
> Date: Friday, 4 December, 2009, 9:44 AM
> how about a little more detail that just saying it 'errors' ?
> Hi everyone.
> I am stuck with this.
> Plz help!!
> Thanks in advance.
> Regards.
> Subject: [mapguide-users] Connection Problem
> Date: Thursday, 3 December, 2009, 6:08 PM
> I have MGOS 2.0 installed on my machine and my sample application is running
> fine
> on my machine using apache and tomcat.
> When I try to access the same application from another machine by providing
> the
> IP Address  of the my machine in the url
> it gives link broken type of errors.
> http://ip/   gives a page which shows It works!
> even
> http://ip/mapguide/  shows the listing of the directories.
> but when i try to access
> http://ip/mapguide/javasamples/main.jsp
> it gives errors but works on my machine.
> can anyone help!!!
> Thanks and Regards.
> The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
> -----Inline Attachment Follows-----
> mapguide-users mailing list
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
> http://in.yahoo.com/
Zac Spitzer
+61 405 847 168
      The INTERNET now has a personality. YOURS! See your Yahoo! Homepage. http://in.yahoo.com/
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091209/5bdaab1c/attachment.html
