[mapguide-users] Internet Guest Account Question
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Dec 9 03:53:22 EST 2009
To clarify, MapGuide does not use the IUSR account, in fact it uses the
"Local System" account.
If you see something with IUSR_, it is because IIS uses this account pr.
default for websites.
(And MapGuide's WebAgent runs from IIS)
You can either use integrated authentication with impersonation, or
change the default user in the
IIS settings for the website. Beware that you will run into multiple
permission issues if you do this.
Regards, Kenneth Skovhede, GEOGRAF A/S
Emily LaMunyon skrev:
> Thanks for the replies. Our IS department has expressed concern over the
> IUSR account being used for Mapguide, due to the possibility of hacks. Maybe
> we are wrong. Is there a problem with just leaving the IUSR alone? Has
> anyone run into this before?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
> Sent: Tuesday, December 08, 2009 12:19 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Internet Guest Account Question
> I believe the issue is a permissions problem after that. The IUSR has
> probably been granted execute permissions on some of the MGE folders in
> order to run the mapagent and access the viewer files. You probably need to
> modify directory permissions to allow whomever your new user is.
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Tuesday, December 08, 2009 12:10 PM
> Subject: Re: [mapguide-users] Internet Guest Account Question
> Not sure about setting the guest account.
> This may be related: I think that trying to set anything but anonymous
> access for MapGuide messes with its internal auth capabilities (which
> use standard http auth req/rest codes). I haven't tried this in quite
> a while though.
> On 2009-12-08, Emily LaMunyon <ELaMunyon at slco.org> wrote:
>> Hello,
>> I am interested in changing the Internet Guest Account that Mapguide uses
> to
>> a private one. How do I get Mapguide to use this instead of the IUSR
>> account? Is this possible?
>> Thanks!
>> View this message in context:
> http://n2.nabble.com/Internet-Guest-Account-Question-tp4134152p4134152.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091209/9d48b1b1/attachment.html
