[mapguide-users] [MGOS 2.1]Wrong coordinate system with GeoTiff files
Hardt preinhart at environcorp.com
Mon Dec 14 04:24:37 EST 2009
Hi all,
I am again fighting with rasters...
I create a dataconnection with GDAL provider, using a Geotiff from ArcGIS
9.3.1.
This GeoTIFF contains the coordinates, and when I add the newly created
layer to a map, it  detects automatically the initial map view correctly.
However, the layer is displayed in meters instead of decimal degrees.
I checked the config file from the dataconnection, and the projection is
LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]
But the GeoTIFF is supposed to be in WGS84 (for the little story, the image
is captured from Google Earth in MapWindow using the Shape2Earth plugin,
then I import it in ArcGis to export it as a GeoTIFF; ArcGIS open it with
decimal degrees, and if I open the GeoTiff in another GIS software, the
GeoTiff is detected as WGS84 too; so to me it's definitely something with
MGOS)
How can I fix this ?
Thanks,
Hardt
View this message in context: http://n2.nabble.com/MGOS-2-1-Wrong-coordinate-system-with-GeoTiff-files-tp4163118p4163118.html
