[mapguide-users] MGOS 2.1 Raster Projection Error
Karl Lai karl.lai at getchee.com
Tue Dec 15 20:36:22 EST 2009
Hi All :
I had serving raster image with MGOS 2.0 for a long time.  When I migrate to
MGOS 2.1, I got some error in error in log file and the raster is not
rendered in Ajax Viewer.  At first I think this is a coordinate system
problem , but when I override the coordinate system with "UTM 51 N" which is
the  same with map's, the error still happen. So I guess maybe someone have
the same problem like this.
Do anyone have idea ?
I am using Windows Server 2003, MGOS 2.1 windows intaller.  And the raster
file is sid/sdw fromat.
Here is the error log:
<2009-11-30T11:17:07> 3052 Ajax Viewer 192.168.10.43 Administrator
 Error: Failed to stylize layer: TaipeiSatImagesAllinFolder
        The coordinate system initialization failed.
        No ellipsoid is allowed on arbitrary coordinate systems.
Map's Coordinate system is
"PROJCS["WGS 84 / UTM zone 51N",GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",123],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32651"]]"
Raster Feature Source's Coordinate system override setting is
Source: Default
Target:
View this message in context: http://n2.nabble.com/MGOS-2-1-Raster-Projection-Error-tp4173360p4173360.html
