[mapguide-users] Look for lines
Jason Birch
jason at jasonbirch.com
Wed Dec 16 00:26:48 EST 2009
No, there's a bug in Maestro. First, make sure you are using the
latest preview release as a fix was applied for this recently. Second
if it still happens (I hit this today and am still working to
recreate) you can open the XML for the layer definition and fix it
manually.
Basically, the second line in the composite set will be missing its
linestyle element and will also likely have its units and
displaycontext set incorrectly. You can copy these from the first line
in the set.
Jason
On 2009-12-15, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> When I tried to use composite lines in a layer ,it is giving the following
> error:
> MapGuide Maestro
> An error occured while saving: The remote server returned an error: (559)
> MgDbXmlException.:
> An exception occurred in DB XML component.
> Error: XML Indexer: Parse error in document at line, 42, char 33. Parser
> message: Element 'Thickness' is not valid for content model:
> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
> Exception occurred in method MgResourceDefinitionManager.UpdateDocument at
> line 601 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> I am using maestro r4208.
> Am I wrong somewhere?
> Thanks and Regards.
> --- On Tue, 15/12/09, Ivan Miličević <Ivan.Milicevic at supranet.hr> wrote:
> From: Ivan Miličević <Ivan.Milicevic at supranet.hr>
> Subject: RE: [mapguide-users] Look for lines
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Tuesday, 15 December, 2009, 5:59 PM
> You can set the composite line Mapguide Studio or Maestro.
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of manav dayal
> Sent: Tuesday, December 15, 2009 12:13 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Look for lines
> Is there an option to display double line for a line (as in google maps)
> using mapguide maestro.
> I am attaching a jpg for comparison.
> Thanks and Regards.
> The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
> -----Inline Attachment Follows-----
> mapguide-users mailing list
> http://in.yahoo.com/
