[mapguide-users] "Failed to read schema..." error with GDAL
Hardt preinhart at environcorp.com
Wed Dec 16 03:41:41 EST 2009
Hi Kenneth,
I recreated the datasource and the layer, to be sure to have an error
message before doing what you said.
The error message popped out as always, but the "View last exception" option
says there is no exception to view.
http://n2.nabble.com/file/n4174355/Capture.png
Kenneth Skovhede, GEOGRAF A/S wrote:
> Hi Hardt,
> In the "About..." menu, can you select the "view last exception",
> and send the message to this list?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> On 14-12-2009 15:55, Hardt wrote:
>> Hi,
>> I created a raster datasource with GDAL.
>> When I create a layer using this datasource, after I selected the Feature
>> Resource, I get an error message saying
>> "Failed read schema from data source.
>> The operation gave the error message: Value cannot be null.
>> Parameter name: input"
>> http://n2.nabble.com/file/n4164488/Capture.png
>> After that, I can select a schema (always default:default), and in the
>> Raster field, sometimes I get "image", sometimes I get "raster" (it seems
>> to
>> depend on which editor I used when I created the datasource)
>> I found no error in MG logs, and the DescribeSchema tool gives me this:
>> <?xml version="1.0" encoding="UTF-8" ?>
>> -<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
>> targetNamespace="http://fdo.osgeo.org/schemas/feature/default"
>> xmlns:fdo="http://fdo.osgeo.org/schemas"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:default="http://fdo.osgeo.org/schemas/feature/default"
>> elementFormDefault="qualified" attributeFormDefault="unqualified">
>> -<xs:element name="default" type="default:defaultType" abstract="false"
>> substitutionGroup="gml:_Feature">
>> -<xs:key name="defaultKey">
>>    <xs:selector xpath=".//default" />
>>    <xs:field xpath="FeatId" />
>>    </xs:key>
>>    </xs:element>
>> -<xs:complexType name="defaultType" abstract="false">
>> -<xs:complexContent>
>> -<xs:extension base="fdo:ClassType">
>> -<xs:sequence>
>> -<xs:element name="FeatId">
>> -<xs:simpleType>
>> -<xs:restriction base="xs:string">
>>    <xs:maxLength value="256" />
>>    </xs:restriction>
>>    </xs:simpleType>
>>    </xs:element>
>>    <xs:element name="Raster" type="fdo:RasterPropertyType"
>> fdo:defaultImageXSize="1024" fdo:defaultImageYSize="1024" />
>>    </xs:sequence>
>>    </xs:extension>
>>    </xs:complexContent>
>>    </xs:complexType>
>>    </xs:schema>
>> I can use the layer in a map, but as I explained in another thread today,
>> there are other problems with coordinate systems etc...
>> What means the "schema" error, and how can I fix it?
>> Thanks,
>> Hardt
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Failed-to-read-schema-error-with-GDAL-tp4164488p4174355.html
