[mapguide-users] Mix of selectfeature and selectaggregate query
Jo Cook j.cook at oxfordarch.co.uk
Wed Dec 16 12:26:42 EST 2009
Hi Dave,
The problem with this approach is that I need to narrow down the available
postcodes first (there are many) so I need some way of passing a filter to
the selectaggregates query and I can't see how to do that. The only options
seem to be spatialfilters and groupingfilters, whereas I want a simple text
filter, unless I'm mistaken?
Thanks
Jo
Dave Wilson wrote:
> I think you want to do your initial query using SelectAggregates and set
> the Distinct flag to get a unique list of Postal Codes. From your result
> page the user could select a code and then you would use a SelectFeatures
> query to return all the actual points adding them to a SelectionSet and
> zooming to that.
> Dave
View this message in context: http://n2.nabble.com/Mix-of-selectfeature-and-selectaggregate-query-tp4176453p4176798.html
