[mapguide-users] Mix of selectfeature and selectaggregate query
Jo Cook
j.cook at oxfordarch.co.uk
Fri Dec 18 07:24:22 EST 2009
Hi Dave,
Thanks for that- I've tried to implement it as a single selectaggregate
query, but I'm still missing something. I suspect (though I don't really
understand what I'm doing) that it's falling over at the dataReader section.
If you (or someone could have a look at my code I'd really appreciate it.
The relevant code is as follows:
MgInitializeWebTier ($webconfigFilePath);
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$map = new MgMap($siteConnection);
$map->Open($mapName);
$filter = "POSTCODE LIKE '$SMAlocation%'";
//echo $filter;
$queryOptions = new MgFeatureAggregateOptions();
$queryOptions->SelectDistinct(true);
$queryOptions->AddFeatureProperty("Postcodegroup");
$queryOptions->SetFilter($filter);
$layers = $map->GetLayers();
$selLayer = $layers->GetItem($SMAlayer);
$featureresourceID = new MgResourceIdentifier($selLayer->
GetFeatureSourceID());
$featureclassname = $selLayer->GetFeatureClassName();
$featureService = new MgFeatureService;
$dataReader =
$featureService->SelectAggregate($featureresourceID, $featureclassname,
$queryOptions);
print_r($dataReader);
$dataReader.close();
echo "<p>Postcodes matching your criteria:</p>";
while ($dataReader->ReadNext()) {
$postcode = $dataReader->GetString('Postcode');
echo $postcode."<br />";
echo"</p>";
Thanks
Jo
Dave Wilson wrote:
> There is a filter on SelectAggregates just like SelectFeatures. You should
> be able to add a PostalCode LIKE clause using this if I am not mistaken.
> Dave
View this message in context: http://n2.nabble.com/Mix-of-selectfeature-and-selectaggregate-query-tp4176453p4186257.html
