[mapguide-users] Mix of selectfeature and selectaggregate query
Jo Cook
j.cook at oxfordarch.co.uk
Fri Dec 18 12:33:55 EST 2009
Hi Jackie,
Well, I'm making progress, in that the query now returns results- as well as
your changes I had to change the type of the featureservice. However,
despite the presence of a groupingfilter and selectdistinct being true, it's
still returning all the results. Any thoughts?
I'm assuming it's something to do with the order of the queryoptions but I'm
not having much luck getting it to work.
Many thanks for your help
Jo
Jackie Ng wrote:
> Two things I see:
> - It looks like 'Postcode' is not part of the properties to be returned.
> Only 'Postcodegroup' is there.
> - You're closing the $dataReader before you're iterating through your
> results, and that call is not correct PHP syntax ($dataReader->Close()
> instead of $dataReader.close())
> Hope that helps
> - Jackie
View this message in context: http://n2.nabble.com/Mix-of-selectfeature-and-selectaggregate-query-tp4176453p4187804.html
