[mapguide-users] the coordinate points is shown in different
locations when i use differnt map server??
Zac Spitzer
zac.spitzer at gmail.com
Mon Dec 21 09:48:29 EST 2009
just tested with maestro with 2.1,
under world co-oridnates is a mercartor projection available :)
(it did take a looong while to open the dialog over a vpn)
2009/12/22 Zac Spitzer <zac.spitzer at gmail.com>:
> so even after the move to the new co ordinate system library,
> the most popular projection on the web requires a manual
> edit in the latest mapguide? surely not?
> 2009/12/22 Jackie Ng <jumpinjackie at gmail.com>:
>> Google/Bing/Yahoo maps use the same mercator projection. Your map needs to be
>> in the same projection information. MapGuide can re-project your layers on
>> the fly.
>> You can find the WKT for the projection here:
>> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
>> - Jackie
>> leena wrote:
>>> hello everyone ;
>>> i have a coordinates data which are supposed to be located in Dubai city;
>>> when i try to view the coordinate locations in google map or any other map
>>> server (yahoo ...etc)
>>> the locations are shown in another city ????
>>> but when i try to few the data with "transcad" it shows the exact correct
>>> locations in Dubai city????
>>> now my question is that if i wanna use mapGuide or google map to few the
>>> same data shall i make some
>>> conversion to the coordinate data to be viewed on them instead of
>>> transcad????
>>> thanks in advance;
>> View this message in context: http://n2.nabble.com/the-coordinate-points-is-shown-in-different-locations-when-i-use-differnt-map-server-tp4196895p4197664.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
