[mapguide-users] Zooming to extent of multiple selections
Jo Cook j.cook at oxfordarch.co.uk
Tue Dec 22 06:24:46 EST 2009
Answered my own question :-)
For information, and future people having a similar problem, the issue was
not with the code but with the fact that the layer came from an odbc data
source, so consequently had no geometry or extents. I figured that out using
the web tier tests. Once I realised that (which was no doubt obvious to most
people) I could extract the values for the coordinates from the table and
use that to construct an envelope for zooming to.
Jo
Jo Cook wrote:
> OK, with some serious searching through the mailing lists, and looking at
> the showgeom.php example in the schemareport folder, I have learnt a
> little more about GetExtents, but I'm still stuck and would very much
> appreciate some assistance. My code is as follows:
> MgInitializeWebTier ($webconfigFilePath);
>                 $userInfo = new MgUserInformation($sessionId);
>                 $siteConnection = new MgSiteConnection();
>                 $siteConnection->Open($userInfo);
>                 echo "Map: ".$mapName."<br />";
>                 $map = new MgMap($siteConnection);
>                 $map->Open($mapName);
>                 $cfilter = "POSTCODE = '$ccode'";
>                 echo "Query: ".$cfilter.'<br />';
>                 $queryOptions = new MgFeatureQueryOptions();
>                 $queryOptions->SetFilter($cfilter);
>                 echo "Layer: ".$SMAlayer.'<br />';
>                 $layers = $map->GetLayers();
>                 $selLayer = $layers->GetItem($SMAlayer);
>                 $featureresourceID = new
> MgResourceIdentifier($selLayer->GetFeatureSourceId());
>                 //print_r($featureresourceID);
> 		$featureclassname = $selLayer->GetFeatureClassName();
>                 $featureService =
> $siteConnection->CreateService(MgServiceType::FeatureService);
>                 $dataReader =
> $featureService->SelectFeatures($featureresourceID, $featureclassname,
> $queryOptions);
>                 $dataReader->ReadNext();
>                 $resourceService =
> $siteConnection->CreateService(MgServiceType::ResourceService);
>                 $selection = new MgSelection($map);
>                 $selection->AddFeatures($selLayer, $dataReader, 0);
>                 $selection->Save($resourceService, $mapName);
>                 $dataReader->Close();
>                 $count =
> $selection->GetSelectedFeaturesCount($selLayer,$featureclassname);
>                 echo 'Count: '.$count.'<br />';
>           	$agfReaderWriter = new MgAgfReaderWriter();
>                 // this seems to be the problem line
> 		$spatialcontextReader =
> $featureService->GetSpatialContexts($featureresourceID, false);
>    		while ($spatialcontextReader->ReadNext())
>                         // Finds the extent
>                         $extentByteReader =
> $spatialcontextReader->GetExtent();
>                 $spatialcontextReader->Close();
> 		// Get the extent geometry from the spatial context
>                 $extentGeometry =
> $agfReaderWriter->Read($extentByteReader);
> 		$iterator = $extentGeometry->GetCoordinates();
>                 while($iterator->MoveNext())
>                     $x = $iterator->GetCurrent()->GetX();
>                     $y = $iterator->GetCurrent()->GetY();
>                     if($firstTime)
>                         $maxX = $x;
>                         $minX = $x;
>                         $maxY = $y;
>                         $minY = $y;
>                         $firstTime = false;
>                     if($maxX<$x)
>                         $maxX = $x;
>                     if($minX>$x||$minX==0)
>                         $minX = $x;
>                     if($maxY<$y)
>                         $maxY = $y;
>                     if($minY>$y||$minY==0)
>                         $minY = $y;
> 		echo "extent lower left: ".$minX.",".$minY."<br />";
> When this runs I get an error that "the argument is null". I believe the
> error is something to do with the spatialcontextreader line, but I can't
> figure out what's wrong with it.
> Any thoughts?
> Jo
View this message in context: http://n2.nabble.com/Zooming-to-extent-of-multiple-selections-tp4199009p4203040.html
