[mapguide-users] MapGuide OSGeo.ODBC FDO not releasing schema cache
neilyoung neil.young at ch2m.com
Tue Dec 22 20:11:00 EST 2009
I am using MGE 2010. Would I be better off getting the xml from studio, and
then loading it back using the crude mapagent interface? I have had trouble
with Maestro not getting along well with my MGE server. Is there a
particular build of Maestro that works well with MGE2010 that I should be
using?
zspitzer wrote:
> that would be need to be done in code....
> just use maestro
> 2009/12/23 neilyoung <neil.young at ch2m.com>:
>> Thanks for the quick reply.
>> Please Forgive my ignorance, but how exactly would I do that?
>> I went to the mapagent index, and selected GetResourceContent, but all i
>> got
>> was a few lines of text. What would I do with that to perform the
>> SetResouceContent?
>> zspitzer wrote:
>>> just save the feature source definition, that will flush the cache
>>> either via studio/maestro or via the api
>>> geResourceContent then  setResourceContent
>>>> I have numerous layers pointing ot the same ODBC connection using a DSN
>>>> pointing to a SQL Server database.
>>>> We have changed the schema, however when looking at the tables, we do
>>>> not
>>>> see the updates to the schema.
>>>> I have disabled caching for the OSGEO.ODBC FDO
>>>> (DataConnectionPoolExcludedProviders = OSGeo.ODBC), and restarted the
>>>> service and the new schema still isn't showing up. Even if I create a
>>>> new
>>>> DSN on the server if the database name referred to in the DSN is the
>>>> same,
>>>> then the old schema still shows up.
>>>> Any ideas on how the cache can be removed? It seems as though it may
>>>> not
>>>> be
>>>> caching, but the the cache still remains.
>>>> All assistance is appreciated.
>>>> View this message in context:
>>>> http://n2.nabble.com/MapGuide-OSGeo-ODBC-FDO-not-releasing-schema-cache-tp4206600p4206600.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> http://n2.nabble.com/MapGuide-OSGeo-ODBC-FDO-not-releasing-schema-cache-tp4206600p4206675.html
> Zac Spitzer
> +61 405 847 168
View this message in context: http://n2.nabble.com/MapGuide-OSGeo-ODBC-FDO-not-releasing-schema-cache-tp4206600p4206719.html
