[mapguide-users] MGOS 2.1 Beta 1 and IIS7.5 Windows 7 64 bits
(and probably Vista, 2008 64bits)
pcardinal
pierre.cardinal at sympatico.ca
Sat Dec 26 21:40:49 EST 2009
antonio.net wrote:
> I was having problems trying to connect to MGOS after a fresh install.
> I was getting a PHP ISAPI Handler 0x800700c1 error.
> Took me some time but finally found the answer here:
> http://forums.iis.net/t/1064155.aspx http://forums.iis.net/t/1064155.aspx
> Where Bill provides this solution:
> <blockquote>
> To fix this issue, you need to make the AppPool as 32bit. Go into the IIS
> Admin tool, browse to your application Pool and click on "Advanced
> Settings". Set the "Enable 32-bit applications" flag to "TRUE". That
> should fix it.
> </blockquote>
> I just leave this here for anyone in the same situation. As I could not
> find any related thread here.
Thank you
View this message in context: http://n2.nabble.com/MGOS-2-1-Beta-1-and-IIS7-5-Windows-7-64-bits-and-probably-Vista-2008-64bits-tp3997664p4219486.html
