[mapguide-users] Virtual Earth Zoom Levels
GordonL
gordon.luckett at arrowgeomatics.com
Thu Dec 31 14:30:49 EST 2009
Yes, this one bugged me too. I created an INVOKESCRIPT in Studio.
Two key things:
(1) if you embed the Fusion in a frame or iFrame you will have to make sure
this is caught (i.e. I use iFrameMap)
(2) Create a white 1px by 1px png file to use as the background.
(3) Use OpenLayers to create the white background.
var map = this.getMap();
var openLayersMap = map.oMapOL;
var googleLayers =
openLayersMap.getLayersByClass('OpenLayers.Layer.Google');
openLayersMap.removeLayer(googleLayers[0]);
var blankLayer = new OpenLayers.Layer.Image("No Base
Layer",'white.png',openLayersMap.maxExtent,new OpenLayers.Size(1,1));
openLayersMap.addLayer(blankLayer);
openLayersMap.setBaseLayer(blankLayer);
window.top.iFrameMap.Fusion.getWidgetById('Map').redraw();
pcardinal wrote:
> Hi gordon
> How did you turn off Google below 1:1128 ?
> Pierre
> GordonL wrote:
>> I haven't been able to go below either limit (even after experimenting
>> with the ranges). I have to turn off Google below the 1:1128 and the VE
>> below the 1:4500 - unfortunately that leaves a very boring map.
>> regards
>> gordon
>> Fraser Burgess wrote:
>>> Hi List
>>> Has anyone been able to implement Virtual Earth in Fusion AND get the
>>> final two zoom levels to work? I notice a few applications around the
>>> net that share the same issue that I'm having.
>>> The max zoom level I'm able to access in MSVE 1:4514.002. Google Earth
>>> will zoom right down to 1:1128.5
>>> Cheers,
>>> Fraser
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Virtual-Earth-Zoom-Levels-tp3829430p4237602.html
