[mapguide-users] Legend and runtime Layer filter
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Feb 2 02:42:35 EST 2009
I have created a seperate ticket with the patch, and noted this on the
original ticket.
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> Kenneth,
> if your suggested cpp patch works, can you upload a diff?
> z
> On Mon, Feb 2, 2009 at 4:36 AM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> Yes, but since the bug is not yet fixed, it is also present in 2.0.2.
>> Matteo skrev:
>> Hi,
>> thanks for the answer. The bug is about 1.2 version of mapguide but i work
>> with 2.0.2 version.
>> Regards, Matteo
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>> That is unfortunately a long standing bug:
>> http://trac.osgeo.org/mapguide/ticket/167
>> You must manually itterate all layers in the layerdefinition,
>> and add the information to the runtime map after startup.
>> Matteo skrev:
>> Hi All,
>> I have some Layer Groups that are hidden when Map is load. When I
>> active
>> the layer group I apply a filter runtime (change the layerdefinition of
>> the
>> layers) to the Layers of group, set the legend visibility of group at
>> true,
>> and refresh the map. I see the objects in the map but I don't see the
>> group
>> in the legend.
>> If I don't set a filter to the layers I see the group in the legend.
>> Why?
>> Can you help me?
>> Thanks
>> Matteo
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090202/b45c3bfb/attachment.html
