[mapguide-users] Integration with Google Earth
Stefan Dalakov
s.dalakov at mapware.net
Mon Feb 2 17:07:36 EST 2009
Have you tried with ArcMap ? Or perhaps you could try to convert a
mapguide layer to KML using web tier test page -
http://localhost:8008/mapguide/mapagent/index.html ?
I have converted several files with both methods and it works. It was
some time ago, but I remember there was a problem in transformation if
the coordinate system of the layer is not Decmal degrees (lat/lon) on WGS 84
If it is a single file and you need just the KML output, I can try
converting it for you
Stefan Dalakov
Sergio Nistal Calvo wrote:
> Hi,
> I´m trying to convert some data in shp format to kml format with
> Shp2kml program and I have two problems: 1 - one of the data, I
> can´t convert because the attribute is "too long, > 100 characters
> (240)", 2 - opening the other data with Google Earth, I get the map
> upside down, as if seen with a mirror, and displaced a few
> meters/kilometers on the right. The coordinate system of the data is
> LOCAL_CS ["Non-Earth (Meter)", LOCAL_DATUM ["Local Datum", 0], UNIT
> ["Meter", 1], AXIS ["X", EAST], AXIS [" Y", NORTH]], but I can´t get
> it shp2kml so I leave the default "WGS 1984 Global Definition" and I
> put "projected UTM (meters), Northern Hemisphere, UTM Zone 32".
> Any help is appreciated.
> Thanks.
> El doble de diversión: Con Windows Live Messenger comparte fotos
> mientras hablas.
> <http://www.microsoft.com/windows/windowslive/messenger.aspx>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090203/18bcb5bc/attachment.html
