[mapguide-users] having a problem for mapGuide
Jackie Ng jumpinjackie at gmail.com
Tue Feb 3 00:34:43 EST 2009
The Apache that comes with MapGuide is just Apache/PHP, it is not a full
WAMP/LAMP stack.
You will have to install mysql/phpmadmin/other components separately.
- Jackie
sara_ghafary wrote:
> thanks
> i examine it afterwards,
> what do  My Project Connect to My Sql ?
> where is PhpMyAdmin ?
> Jackie Ng wrote:
>> If you only have wamp installed on the (false) belief is is required for
>> MapGuide development, then you can safely uninstall it.
>> Apache's web root (that is installed with MapGuide) is at:
>> <your mapguide install directory>\WebServerExtensions\www
>> (ie. D:\Program Files\MapGuideOpenSource\WebServerExtensions\www)
>> This corresponds to a url of http://localhost:8008/mapguide (assuming
>> default settings)
>> Drop your PHP project in this directory and it will be accessible.
>> eg. If your PHP project is in:
>> D:\Program Files\MapGuideOpenSource\WebServerExtensions\www\MyProject
>> It can be accessed via this URL:
>> http://localhost:8008/mapguide/MyProject/<my starting page>.php
>> - Jackie
>> sara_ghafary wrote:
>>> thank you
>>> do i must deleted Wamp?
>>> Map guide  Web Extensions  installed in D:\Program Files
>>> \MapGuideOpenSource
>>> so ,where do  My PHP project  attach?
>>> what do parameter Pass between  My PHP Project and Map guide  Web
>>> Extensions ? :confused:
>>> Jackie Ng wrote:
>>>> I assume you have just installed MapGuide onto a machine that has an
>>>> existing WAMP installation.
>>>> If you installed MapGuide Web Extensions with the Apache/PHP option, it
>>>> is actually installing its own instance of Apache and PHP, and not
>>>> using the one in your WAMP installation.
>>>> - Jackie
>>>> sara_ghafary wrote:
>>>>>  hi ,
>>>>> i have a problem for mapGuide! ,i install SoftWares  "MapGuide Server"
>>>>> and "MapGuide Web Server Extensions"  ,when instal in drive
>>>>> "D:\Program files\MapGuideOpenSource"
>>>>> my php project   exist in c:\wamp\www  ,
>>>>> i do not khnow  how pass parameter between 2 project!
>>>>> please Help me
>>>>> tanks
View this message in context: http://n2.nabble.com/having-a-problem-for-mapGuide-tp2212083p2261851.html
