[mapguide-users] SQL datetime trouble
Darren Karasiuk
darren.karasiuk at aldatasoftware.com
Tue Feb 3 12:41:51 EST 2009
Hello, and thank you both for your response. (*^-^)
Solution:
"DateColumn" > TIMESTAMP '2009-01-30 23:25:00'
I wasn't aware of the TIMESTAMP operator. Using it solved my problem and I
can now filter by date range. ( ^O^)/
Thanks for your time!
Darren
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: February 3, 2009 12:41 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] SQL datetime trouble
I have found the FDO "TIMESTAMP" command to works for me:
It might not work on all providers though.
Regards, Kenneth Skovhede, GEOGRAF A/S
Traian Stanev skrev:
This is more of a workaround than a solution to the problem, but. You can
try to make some expression that converts the date to a string of the form
YYYY-MM-DD and then write your filter as a string comparison. You can
compare dates in this format using simple string comparisons
(lexicographical order matches chronological order).
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Darren Karasiuk
Sent: Monday, February 02, 2009 2:09 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] SQL datetime trouble
Hello, I've been trying to use MapGuide OS and have been able to show a
themed layer when I filter by the unique row id and equipment id. Instead
of using row IDs, I need to filter the data by date and time ranges. So
far, when ever I use a datetime field to filter, the entire database is
returned. I assume if the filter isn't correct then it's nulled and no
filter gets applied, so that's why I get the entire database.
Can anyone tell me the correct method of filtering a layer by a date range,
please?
I've been using Map Guide Studio trial from Autodesk and tried many
different ways of filtering using ToDate() and Extract() with no luck.
I couldn't find any filtering information with the FDO.
I'm using SQL Server 2008. The table has both lat and long fields as well as
its respective geospatial field.
Thanks for any help!
Darren
_____
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090203/d50ff1b3/attachment.html
