[mapguide-users] Thematic Mapping
padmini godavarthi
godavarthi.padmini at gmail.com
Wed Feb 4 04:53:48 EST 2009
Hi Chris,
Thanku very much ur help.i used different colours in InterpolateColor
functions. but i got the same color to all my parcels.
I solved this error by setting setfilter option to the aggregateoptions.
Here is my code
public string ApplyTheme2()
NameValueCollection serverVars = Request.ServerVariables;
String strServerVars = "";
foreach (String str in serverVars.AllKeys)
strServerVars += "<br>" + str;
String platform = serverVars["SERVER_SOFTWARE"];
String queryStr = serverVars["QUERY_STRING"];
string queryStr1 = serverVars["Form"];
NameValueCollection requestParams = Request.HttpMethod == "POST" ?
Request.Form : Request.QueryString;
String sessionId = Request.QueryString["SESSION"];
string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
String configPath = realPath + "webconfig.ini";
MapGuideApi.MgInitializeWebTier(configPath);
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService resourceService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
MgFeatureService featureService =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
MgMap map = new MgMap();
map.Open(resourceService, "mapdata");
MgLayerCollection layers = map.GetLayers();
MgLayer layer = (MgLayer)layers.GetItem("property layer");
MgResourceIdentifier resId = new
MgResourceIdentifier(layer.GetFeatureSourceId());
MgResourceIdentifier layerDefResId = layer.GetLayerDefinition();
MgByteReader byteReader =
resourceService.GetResourceContent(layerDefResId);
// Load the Layer Definition and Navigate to the specified
<VectorScaleRange>
XmlDocument doc = new XmlDocument();
String xmlLayerDef = byteReader.ToString();
doc.LoadXml(xmlLayerDef);
XmlNodeList nodeList =
doc.GetElementsByTagName("VectorScaleRange");
XmlElement vectorScaleRangecElement = (XmlElement)nodeList.Item(0);
XmlElement areaTypeStyle =
(XmlElement)vectorScaleRangecElement.GetElementsByTagName("AreaTypeStyle").Item(0);
// Remove any existing <AreaRule> elements.
XmlNodeList areaRuleList =
areaTypeStyle.GetElementsByTagName("AreaRule");
int count = areaRuleList.Count;
for (int i = 0; i < count; i++)
//The areaRuleList shrinks as we remove items, so always
//remove the first item (don't use the index i)
areaTypeStyle.RemoveChild(areaRuleList.Item(0));
// Now create the new <AreaRule> elements.
String areaRuleTemplate =
File.ReadAllText(GetThemeXmlTemplatePath());
MgFeatureAggregateOptions aggregateOptions = new
MgFeatureAggregateOptions();
String value = null;
String filterText = null;
String areaRuleXML = null;
XmlDocument areaDoc = null;
XmlNode areaNode = null;
double portion = 0.0;
aggregateOptions.AddFeatureProperty("FeatId");
aggregateOptions.SelectDistinct(true);
String totquery = "FeatId" + "=" + "2984";
aggregateOptions.SetFilter(totquery);
double increment = (5 > 1) ? 1.0 / (5 - 1) : 1.0;
MgDataReader dataReader = featureService.SelectAggregate(resId,
layer.GetFeatureClassName(), aggregateOptions);
while (dataReader.ReadNext())
value = GetFeaturePropertyValue(dataReader, "FeatId");
filterText = """ + "FeatId" + "" = ";
filterText = filterText + value;
areaRuleXML = String.Format(areaRuleTemplate,
"FeatId" + ":" + value,
filterText,
InterpolateColor(portion, "C2C3C4", "C2C3C4", 0), InterpolateColor(portion,
"C2C3C4", "C2C3C4", 0));
areaDoc = new XmlDocument();
areaDoc.LoadXml(areaRuleXML);
areaNode = doc.ImportNode(areaDoc.DocumentElement, true);
areaTypeStyle.AppendChild(areaNode);
portion = portion + increment;
dataReader.Close();
MgFeatureAggregateOptions aggregateOptions1 = new
aggregateOptions1.AddFeatureProperty("FeatId");
aggregateOptions1.SelectDistinct(true);
String totquery1 = "FeatId" + "<>" + "2984";
aggregateOptions1.SetFilter(totquery1);
double increment1 = (5 > 1) ? 1.0 / (5 - 1) : 1.0;
MgDataReader dataReader1= featureService.SelectAggregate(resId,
layer.GetFeatureClassName(), aggregateOptions1);
while (dataReader1.ReadNext())
value = GetFeaturePropertyValue(dataReader1, "FeatId");
filterText,
InterpolateColor(portion, "000000", "000000", 0), InterpolateColor(portion,
"000000", "000000", 0));
areaDoc.Save("C:\\theme.xml");
dataReader1.Close();
// Now save our new layer definition to the session and add it to
the map.
String xmlString = doc.DocumentElement.OuterXml;
String uniqueName = this.MakeUniqueLayerName(map, "property layer",
"sample");
String legendLabel = layer.GetLegendLabel();
if ("sample".Length > 0)
legendLabel = legendLabel + " (" + "sample" + ")";
MgResourceIdentifier layerResId = new
MgResourceIdentifier("Session:" + sessionId + "//" + uniqueName +
".LayerDefinition");
resourceService.SetResource(layerResId, new MgByteReader(xmlString,
"text/xml"), null);
MgLayer newLayer = new MgLayer(layerResId, resourceService);
newLayer.SetName(uniqueName);
newLayer.SetLegendLabel(legendLabel);
newLayer.SetDisplayInLegend(layer.GetDisplayInLegend());
newLayer.SetVisible(true);
newLayer.SetSelectable(layer.GetSelectable());
layers.Insert(layers.IndexOf(layer), newLayer);
map.Save(resourceService);
return uniqueName;
now iam able to get different colour to the polygon (having Property as
FeatId=2984 ) other polygons were in different colour.
Now my problem is that this works fine for Filebased Package(Shapefile).When
i used this code for oracle based package i got an error at
aggregateoption.Setfilter option
the error was
"An exception of type 'OSGeo.MapGuide.MgFdoException' occurred in
MapGuideDotNetApi.DLL but was not handled in user code"
can u plz tell me so it will be helpful to me.
Thanks and Regards,
Padmini.
Chris Claydon wrote:
> Hi Padmini,
> The InterpolateColor() function in your code below has a method signature
> like this:
> private String InterpolateColor(double portion, String startColor, String
> endColor, int percentTransparent)
> You should set the startColor string to be the first color you want to use
> in your range of colors, and the endColor string to be the last color.
> Then, depending on the value of the "portion" parameter that you pass in,
> the resulting color will fall somewhere in the range you've specified.
> In the code you've included below, you have two calls to
> InterpolateColor(). One of them controls the fill color of your polygons
> and the other controls the edge color. The problem is that in each call,
> you've still specified that the startColor is the same as the endColor.
> For example:
> InterpolateColor(portion, "C2C3C4", "C2C3C4", 0) will only ever return you
> the color that corresponds to "C2C3C4". If you change one of the strings,
> you should see some color variation. E.g.
> InterpolateColor(portion, "00FF00", "FF0000", 0)
> Try that and see what happens.
> It seems to me that you do not yet have a very strong understanding of how
> the code below actually functions. I would urge you to spend some time
> looking at it to try to figure it out. I appreciate that some of it is
> quite complex, and you should feel free to ask questions on the newsgroup
> to help you. I can't claim to speak for anyone else on this group, but
> personally I would rather help others to learn to understand the
> framework, and write their own code, than simply to provide pre-written
> solutions to their problems.
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
> godavarthi
> Sent: Sunday, February 01, 2009 9:22 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Thematic Mapping
> Hi z,
> Thanku very much for ur suggestions.i will respect it.
> but i understood the answer given by Chris.
> But i think its not correct solution for my original query.
> i want to display different colors to the different polygons.
> but while applying 2 colors in the InterpolateColor function it doesn't
> change in different colors
> filterText,
> it displays some yash color to all the polygons,but i want different color
> Can u plz help me
> Thanks and Regards,
> Padmini G.
> zspitzer wrote:
>> when someone takes times to provide a response, it's respectful to taking
>> a bit more time to read your original email AGAIN !
>> your calling
>> InterpolateColor(portion,"C2C3C4", "C2C3C4", 0));
>> which takes two colors to create a range, yet you pass in the same
>> color twice....
>> sorry if I sound a bit grumpy, but it appears that Chris spent more
>> time reading
>> your email that you did after his reply....
>> z
>> On Sat, Jan 31, 2009 at 7:57 PM, padmini godavarthi
>> <godavarthi.padmini at gmail.com> wrote:
>>> Hi,
>>> Thanks for ur reply.but i didn't get u
>>> can u plz tell me briefly so that it will be helpful to me.
>>> Thanks and Regards,
>>> Padmini.
>>>> I would recommend modifying your call to InterpolateColor() so that the
>>>> start color and end color correspond to the colors you want. They are
>>>> currently both set to the same string.
>>>> godavarthi
>>>> Sent: Friday, January 30, 2009 3:59 AM
>>>> Subject: [mapguide-users] Thematic Mapping
>>>> Hi,
>>>> iam using mpguide opensource 2.0 (.net 2.0 +IIS 5.1).
>>>> I want to do thematic mapping for polygon layer(for example parcel
>>>> layer)
>>>> i tried to use the code in dotnetviewer sample.its working fine
>>>> iam able to create a thematic layer with same color to the all
>>>> polygons.
>>>> Now my problem is that i want to apply different colours to the
>>>> different
>>>> polygons
>>>> for example for parcel_id =1 ------------ green colour
>>>> for example for parcel_id =2 ------------ Red colour and
>>>> soon.........................
>>>> for this can u plz tell me the code for how to do it?
>>>> my code was as follows
>>>> "POST"
>>>> string realPath =
>>>> <VectorScaleRange>
>>>> filterText,
>>>> true);
>>>> dataReader.Close();
>>>> to
>>>> the map.
>>>> layer",
>>>> "sample");
>>>> "text/xml") , null);
>>>> return uniqueName;
>>>> String
>>>> int alpha = (int)(255 * (100.0 - percentTransparent) / 100.0);
>>>> String result = "";
>>>> if (startColor.Equals(endColor))
>>>> result = String.Format("{0:X2}{1}", alpha, startColor);
>>>> else
>>>> int red = CalculateRGB(portion, startColor.Substring(0, 2),
>>>> endColor.Substring(0, 2));
>>>> int green = CalculateRGB(portion, startColor.Substring(2,
>>>> 2),
>>>> endColor.Substring(2, 2));
>>>> int blue = CalculateRGB(portion, startColor.Substring(4,
>>>> 2),
>>>> endColor.Substring(4, 2));
>>>> result = String.Format("{0:X2}{1:X2}{2:X2}{3:X2}", alpha,
>>>> red,
>>>> green, blue);
>>>> return result;
>>>> private String MakeUniqueLayerName(MgMap map, String layerName,
>>>> String
>>>> themeName)
>>>> String desiredName = "_" + layerName + themeName;
>>>> String uniqueName = desiredName;
>>>> int index = 1;
>>>> while (map.GetLayers().Contains(uniqueName))
>>>> uniqueName = desiredName + index.ToString();
>>>> index++;
>>>> return uniqueName;
>>>> private int CalculateRGB(double portion, String startRGB, String
>>>> endRGB)
>>>> double result = Int32.Parse(startRGB, NumberStyles.HexNumber) +
>>>> portion * (Int32.Parse(endRGB, NumberStyles.HexNumber) -
>>>> Int32.Parse(startRGB, NumberStyles.HexNumber));
>>>> return (int)result;
>>>> String GetThemeXmlTemplatePath()
>>>> String xmlTemplatePath ="D:\\arearuletemplate.xml";
>>>> return xmlTemplatePath;
>>>> can u plz tell me the solution?
>>>> Regards,
>>>> Padmini.
>>>> View this message in context:
>>>> http://n2.nabble.com/Thematic-Mapping-tp2244230p2244230.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://n2.nabble.com/Thematic-Mapping-tp2244230p2249312.html
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
> http://n2.nabble.com/Thematic-Mapping-tp2244230p2256479.html
View this message in context: http://n2.nabble.com/Thematic-Mapping-tp2244230p2267929.html
