[mapguide-users] fusion methodology
Arnaud De Groof Arnaud.DeGroof at spacebel.be
Wed Feb 4 10:33:12 EST 2009
In fact, I will try to use the following php applications: "theme
layer", "search" and "query".
With Mapguide Maestro (1.0.9), I have configured new widgets for these
applications.
Example (xml tag - I suppose that the "Type" is incorrect):
<Widget xsi:type="UiWidgetType">
<Name>Test</Name>
<Type>About</Type>
<Location />
<Extension>
<AboutURL>/mapguide/phpviewersample/Aquasid/theme/thememain.php</AboutUR
L>
</Extension>
<ImageUrl />
<ImageClass />
<Label>Test</Label>
<Tooltip />
<StatusText />
<Disabled>False</Disabled>
</Widget>
When I launch the application in the flexible layout, I encounter the
following error:
Error
Invalid argument(s): [1] = "" The session ID is invalid because the
session separator character was not found. Invalid argument(s): [1] = ""
The session ID is invalid because the session separator character was
not found. Exception occurred in method MgUserInformation.SetMgSessionId
at line 183 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecomm
on\System/UserInformation.cpp
According the comments from Chris (see
http://n2.nabble.com/Fusion-php-application---error-session-ID-td2204137
.html), I have modified the variable "SESSION" by "session" but without
success.
Thanks
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090204/5ef4058a/attachment.html
