[mapguide-users] MapGuide REST Extension
Jason Birch
Jason.Birch at nanaimo.ca
Wed Feb 4 14:20:28 EST 2009
Not sure why you would want to pass those features as a GET?
Are you maybe talking about selection or buffering by a user-defined
polygon? If so, then the correct pattern would be to post that feature
to a session-based resource, and then reference that resource when doing
the selection.
Hmm. I don't think that the framework currently supports accessing
session-based resources, but that's certainly something to think about.
Haris, do you have any insight into this?
The other option would be to send a POST with a "method" override in
either the HTTP headers or as a parameter. Doing this breaks REST
design philosophy, and I wouldn't be all that happy to see it as a
primary access method, but many frameworks allow it.
Jason
-----Original Message-----
Subject: Re: [mapguide-users] MapGuide REST Extension
the REST extension looks really promising. I particularly like the
"code-free" aspect to extract attributes and coordinates of the
features.
Have you found it limiting due to the GET limitations. For example, I
often have features with thousands of vertices, and it would be
difficult
passing those features as a GET...
