[mapguide-users] Connecting to WMS
Gunter Becker gunter.becker at csogis.de
Thu Feb 5 09:00:49 EST 2009
please have a look at  http://trac.osgeo.org/mapguide/ticket/600 trac ticket
600 .
I think that is the same problem.
Gunter
Stefan Dalakov wrote:
> Hi Kenneth,
> I explored the error log.
> The problem is that coordinate systems do not match BUT :
> 1. The error log says
> /The coordinate system (*EPSG:32633*) of layer RissaWMSLayer1 cannot be
> different than the coordinate system (*EPSG:32632*) of the map
> /2. The wms layer is configured to use /*EPSG:32632 */- in my config.xml
> it is written
> /      <RasterDefinition name="Image">
>         <Format>PNG</Format>
>         <Transparent>true</Transparent>
>         <BackgroundColor>0xFFFFFF</BackgroundColor>
>         <Time>current</Time>
>         <Elevation>0</Elevation>
>         <SpatialContext>*EPSG:32632*</SpatialContext>
>         <Layer name="VERANDA">
> /3. The service supports this coordinate system - in GetCapabilities
> document I have
> <SRS>EPSG:32633</SRS>
> <BoundingBox SRS="EPSG:32633" minx="218329.98786561"
> miny="7160648.90075887" maxx="305197.974972341" maxy="7041546.39019898"/>
> *<SRS>EPSG:32632</SRS>
> <BoundingBox SRS="**EPSG:32632" minx="506720" miny="7147644"
> maxx="604333" maxy="7037305"/>
> *<SRS>EPSG:32634</SRS>
> <BoundingBox SRS="EPSG:32634" minx="-68103.0343048812"
> miny="7200948.9760428" maxx="7352.92691530631" maxy="7073836.91252369"/>
> <SRS>EPSG:9804</SRS>
> <BoundingBox SRS="EPSG:9804" minx="1017422.41132931"
> miny="9427477.01214373" maxx="1234782.60719126" maxy="9172903.66920839"/>
> So, I want the map and WMS layer to be in coordinate system *32632*, the
> Feature source is configured to use this coordinate system, the service
> supports it, but still the server sends the output in *32633.*
> Can you spot my mistake ?
> Best regards : Stefan Dalakov
> /Kenneth Skovhede, GEOGRAF A/S wrote:
>> Since a WMS layer is a raster layer, MapGuide requires that the
>> Coordinate System of the layer is EXACTLY the same as for the map.
>> This means that the Coordinate System Override on the layer must match
>> the map's Coordinate System exactly.
>> To see if there are any errors reported, look in the error log:
>> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Stefan Dalakov skrev:
>>> Hi all,
>>> I am trying to add a WMS layer to my map.
>>> I followed the procedure described here :
>>> https://trac.osgeo.org/fdo/wiki/FdoWmsNotes
>>> to create a feature source.
>>> When I open the feature source in Studio the connection tests OK.
>>> Clicking the *Refresh* button generates an error originating from
>>> displayschema.php at line :
>>> /document.getElementById("Geom_"+"RissaWMS").previousSibling.firstChild.src
>>> = "./images/collapse_pane.png";
>>> /for each layer in the WMS feature source which is not critical
>>> (critical for Studio)
>>> *View Data *link then reports BBOX parameter missing, which I assume
>>> is normal
>>> I create a Layer afterwards, based on this Feature Source. The layer
>>> seems ok - refreshes OK, nothing on screen . This I also assume
>>> normal as  the layers (as described in the  GetCapabilities
>>> document)  are  limited to scale ranges  up to 1:5000.
>>> I add this layer to an existing map, with matching coordinate system
>>> (EPSG:32632 of the WMS Feature Source and UTM-WGS84 / Zone 32 North
>>> of the map).
>>> The WMS layer is not shown on the preview in Studio - perhaps this is
>>> also normal - my other raster layers are not previewed either.
>>> But when I don't see the layer data in browser I am really stressed.
>>> And my biggest stress is based on the fact that I do not know how to
>>> debug this situation
>>> Any help will be highly appreciated
>>> Thank you in advance : Stefan Dalakov
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Connecting-to-WMS-tp2270211p2274991.html
