[mapguide-users] problem in installing map guid eopen source in Fedora 9
Jack Lee jack.lee at sympatico.ca
Thu Feb 5 09:07:16 EST 2009
Are you sure there wasn't any previous error building xalan?
kapilmanoj wrote:
> Hi all,
> i am using fedora 9......  i am trying to install map guide open source....
> i am struggling for the past one week to install in fedora 9.... i followed
> the instructions and procedures very keenly given in the installation
> document but i failed ....
>     i installed  apache and php separately using the command YUM INSTALL
> ....  i didnt use the tar ball mapguideaptinstaller-2.0.x.tar.gz  which one
> is providing  by the map guide open source from their website  to build and
> install apache and php ...
> Then i installed all the FDO  and the providers....  here come the problem
> arised , when i was trying to build and install the FDO using the following
> step...
> ./build_thirdpary.sh
> it thrown me a error message at the end of the completion of building....
> make[2]: Leaving directory `/root/OpenSource_FDO/Thirdparty/openssl/test'
> make[1]: Leaving directory `/root/OpenSource_FDO/Thirdparty/openssl/test'
> making all in tools...
> make[1]: Entering directory `/root/OpenSource_FDO/Thirdparty/openssl/tools'
> make[1]: Nothing to be done for `all'.
> make[1]: Leaving directory `/root/OpenSource_FDO/Thirdparty/openssl/tools'
> Building of the Thirdparty/GDAL libraries has been skipped. Environment
> variable FDOGDAL points to a previously installed version of GDAL at . This
> version of GDAL will be used to build the FDO WMS and GDAL providers.
> make[1]: Entering directory `/root/OpenSource_FDO/Thirdparty'
> make[1]: *** No rule to make target
> `apache/xml-xalan/c/lib/libxalan-c.so.17.0', needed by `all-am'.  Stop.
> make[1]: Leaving directory `/root/OpenSource_FDO/Thirdparty'
> make: *** [install-recursive] Error 1
> Ans also when it was building FDO i noticed some FAILURE  STATEMENT...
> GCC COMPILER FAILED....
> I installed GCC version  ---    gcc (GCC) 4.3.0 20080428 (Red Hat 4.3.0-8)..
> so can anyone please facilitate me and figured it out my problem..
> regards
> kapil
> iitmk
