[mapguide-users] Regarding Flexible Layout
Mark Pendergraft
markp at Meadgilman.com
Thu Feb 5 14:09:26 EST 2009
Yes, but as long as the user has PHP installed (a must for MGOS in
general) they shouldn't have any issues at all. I'm programming in
VS2008, and can include ASPX pages in my Fusion App, interact with VB
.NET server side code, and can even get the same code in the index.html
page to run inside of a index.aspx page with no errors. The Fusion code
is all in javascript, and there is no reason why an application can't
use both PHP and ASP.
I'm guessing that their application is breaking due to a lack of
reference to the fusion.js library or maybe a div not being in the page
with the same name as the jx component that is being created, or a bad
applicationdefintion.xml file.
-Mark
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Thursday, February 05, 2009 10:55 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Regarding Flexible Layout
Perhaps that isn't worded correctly but the server-side component of
Fusion is in PHP only at the moment.
Mike
Mark Pendergraft wrote:
> What do you mean "not supported in an ASP environment"???
> -Mark
> From: mapguide-users-bounces at lists.osgeo.org
Adair
> Sent: Thursday, February 05, 2009 9:11 AM
> The Jx.Dialog suggests to me that you are using the Fusion viewer
which
> isn't supported in an ASP environment.
> Mike
>> Can you post the contents of your index.html file please?
>> -Mark
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>> *ravinder.singh at BIRLASOFT.COM
>> *Sent:* Wednesday, February 04, 2009 10:48 PM
>> *To:* mapguide-users at lists.osgeo.org
>> *Subject:* [mapguide-users] Regarding Flexible Layout
>> Hi,
>> Please assist me. I am very new to GIS development.
>> Developing a GIS application in asp.net. When I tried to run the
>> *basic layout* of Sheboygan sample provided its running fine. But the
>> flexible layouts are not running. I have tried to run it from the
>> dotnetsampleviewer, mapguide maestro but I am getting the same error
>> "*object doesn't support this property or method*". And when I try to
>> debug it takes me to
>> dOverviewMap = new Jx.Dialog({id: 'dialogOverviewMap', imageBaseUrl:
>> 'images/',
>> title: OpenLayers.String.translate('ovmapTitle'),
>> modal: false, resizeable: false,
>> right: 50, bottom: 50, width: 200, height: 200,
>> contentID: 'OverviewMap', helpID: '' } );
>> this point.
>> I am using
>> 1.MgServerSetup-2.0.1.2716
>> 2.MgWebServerExtensionsSetup-2.0.1.2716
>> 3.Dotnetviewersample
>> 4.Sheboygan.mgp
>> *Regards,*
>> Ravinder
>> "This message and any attachments are solely for the intended
>> recipient and may contain Birlasoft confidential or privileged
>> information. If you are not the intended recipient,any
>> disclosure,copying, use, or distribution of the information included
>> in this message and any attachments is
>> prohibited. If you have received this communication in error, please
>> notify us by reply e-mail at (administrator at birlasoft.com) and
>> permanently delete this message and any attachments. Thank you."
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
madair at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
