[mapguide-users] Working with state plane data in Mapguide studio
clarkie342
f2000342 at gmail.com
Thu Feb 5 20:19:04 EST 2009
Could you send a screenshot of what you see in Studio? Just want to make sure
it looks ok, that way I know my studio is doing something since we both have
the same sdf. Thanks.
Mark Pendergraft wrote:
> Okay, the Facility.sdf shows up in Civil 3d and in MapGuide Studio. I
> can select features and I can zoom in as well.
> I've had trouble exporting features using Civil 3D in the past, it's
> tricker than it looks.
> What is distorted about the feature in MapGuide Studio? What version of
> MapGuide Studio do you have?
> -Mark
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
> Sent: Thursday, February 05, 2009 3:44 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Working with state plane data in Mapguide
> studio
> I see the feature when I export it to shp and open it in arcmap.
> attached in another layer from the DWG which shows up in Civil 3D but is
> distorted in Mapguide studio. It also does not let me select features or
> zoom properly.
>> Odd, that file shows no features in Civil 3D or in MapGuide Studio
> 2009.
>> What do you see when you open it in ArcMap?
> clarkie342
>> Sent: Thursday, February 05, 2009 3:13 PM
> Mapguide
>> studio
>> I am using Autodesk 2009. so its File->Convert DWG to Autodesk SDF
>> option.
>> Publish to mapguide option seems to create dwf instead of SDF. I need
>> sdf.
>> The coordinate system seems to be ok since it works well with shp in
>> Arcmap.
>> It is assigned and the right coordinate system is detected during the
>> export.
>> Here is a sample sdf. Thanks.
>> Andy Morsell wrote:
>>> It's probably a coordinate system issue. Have you assigned the
> proper
>>> coordinate system to the DWG project itself as well as specify it
> when
>> you
>>> export? Which version of Autodesk Map are you using? Are you using
>> the
>>> Map->Tools->Export to Autodesk MapGuide option or are you using the
>>> Publish
>>> to MapGuide option?
>>> Andy Morsell, P.E.
>>> Spatial Integrators, Inc.
>>> www.SpatialGIS.com
>> clarkie342
>>> Sent: Thursday, February 05, 2009 2:25 PM
>>> Subject: [mapguide-users] Working with state plane data in Mapguide
>> studio
>>> I have some data in State Plane coordinate system (AL83-EF) in a
>> AutoCAD
>>> dwg.
>>> I exported this data to SDF and opened in Mapguide Stuiod, data does
>> not
>>> show up in the layer preview.
>>> Exporting it to shp and opening it in Arcmap works fine. Any ideas?
>>> Thanks.
>>> View this message in context:
> http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp
>> 2277
>>> 697p2277697.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/file/n2278016/boundary.zip boundary.zip
>> 2277697p2278016.html
> http://n2.nabble.com/file/n2278132/Facility.zip Facility.zip
> 2277697p2278132.html
View this message in context: http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp2277697p2278488.html
