[mapguide-users] Can I use MGSERVER2008 in both Appache and
onsame machine?
Dave Wilson
dave.wilson at autodesk.com
Fri Feb 6 19:07:57 EST 2009
That's possible.
Do a change and modify the install. Add the .NET stuff.
Configure the mapviewerajax as an application that points to the mapviewernet folder. Make the default doc the ajaxviewer.aspx file. Make the mapviewernet folder an application as well. The install should create a bin folder with the required MG dlls.
I think that's mostly it.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, February 06, 2009 12:58 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Can I use MGSERVER2008 in both Appache and onsame machine?
I'm guessing that as long as Apache isn't running on port 80, you could
also perform a repair install on the web extensions to add the .Net
dlls, and then configure the mapguide virtual directories manually in
IIS. There is info floating around there somewhere on how to do this.
Jason
onsame machine?
Yes. Just uninstall the web tier and reinstall it with .NET. Don't touch
the mgserver install.
Sent: Friday, February 06, 2009 8:40 AM
Subject: [mapguide-users] Can I use MGSERVER2008 in both Appache and on
same machine?
I am new and now working with MGSERVER on Apache Web Server with Php, I
would
like to study MapGuide API using ASP.NET, can I change MGSERVER to IIS
on
same machine?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
