[mapguide-users] window open
DYUTI
dyuti152006 at yahoo.com
Mon Feb 9 01:54:03 EST 2009
thank u mark
my platform is mapguide maestro..my map having 3 layers.The third
layer having lot of points that points some places on the map,while clicking
on these points a window should open.that contain info about the particular
place..i'm newer in this..so plss help me....
thanks
dyuti
Mark Pendergraft wrote:
> What exactly are you trying to do? If you have points in your map, you
> can have a URL display in the map tip, when hovering over the point.
> You can also pass parameters to the URL string using an expression. All
> of that can be done by editing the layer in MapGuide Studio.
> If you can provide more information about what you would like your map
> to do, I'm sure someone here could point you in the right direction.
> -Mark P.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
> Sent: Sunday, February 08, 2009 8:20 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] window open
> hi..all...
> to open a new window while clicking on the points displayed
> on
> the map where i've to write the coding...In which file i've to make
> changes..&what change i've to make...plss help me...
> thanks®ards
> dyuti
> http://n2.nabble.com/window-open-tp2295629p2295629.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/window-open-tp2295629p2296031.html
