[mapguide-users] window open
DYUTI
dyuti152006 at yahoo.com
Tue Feb 10 23:44:46 EST 2009
hi all.....
would anyone plss help me to write a widget for open a pop up
window...i'm newer in mapguide&fusion.i don't know whether i'm in right
direction...so plss help me ...
thanks®ards
dyuti
DYUTI wrote:
> yes....i'm using fusion.would anyone plss explain how to write a widget?
> thax ®ards
> dyuti
> Mark Pendergraft wrote:
>> Are you using Fusion? I think the best choice would be to write a
>> widget.
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
>> Sent: Sunday, February 08, 2009 11:05 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] window open
>> please refer this link then u'll get an idea about what i'm trying to do
>> http://www.edugrid.ac.in/webgis/2/keralainfo/
>> DYUTI wrote:
>>> thank u mark
>>> my platform is mapguide maestro..my map having 3 layers.The
>>> third layer having lot of points that points some places on the
>> map,while
>>> clicking on these points a window should open.that contain info about
>> the
>>> particular place..i'm newer in this..so plss help me....
>>> thanks
>>> dyuti
>>>> What exactly are you trying to do? If you have points in your map,
>> you
>>>> can have a URL display in the map tip, when hovering over the point.
>>>> You can also pass parameters to the URL string using an expression.
>> All
>>>> of that can be done by editing the layer in MapGuide Studio.
>>>> If you can provide more information about what you would like your
>> map
>>>> to do, I'm sure someone here could point you in the right direction.
>>>> -Mark P.
>>>> Sent: Sunday, February 08, 2009 8:20 PM
>>>> Subject: [mapguide-users] window open
>>>> hi..all...
>>>> to open a new window while clicking on the points
>> displayed
>>>> on
>>>> the map where i've to write the coding...In which file i've to make
>>>> changes..&what change i've to make...plss help me...
>>>> thanks®ards
>>>> dyuti
>>>> View this message in context:
>>>> http://n2.nabble.com/window-open-tp2295629p2295629.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/window-open-tp2295629p2296057.html
View this message in context: http://n2.nabble.com/window-open-tp2295629p2306878.html
