[mapguide-users] Connect to PostgreSQL database via DNS (Mapguide
Studio 2009)
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Feb 12 02:36:06 EST 2009
Have you tried both the PostGIS provider and the OGR provider?
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi Kenneth,
> Thank you very much for your time.
> I followed your suggestion and I still unable to do it.
> I tested the connection with a diferent piece of software and I was able to
> do it. I tried to access and create a layer based on the data on my database
> using Quantum GIS it works fine, only with Mapguide I am not able to do it.
> I went to check if there is any error in the log files and nothing.
> Do you have any other suggestion ofr my problem?
> Thanks again for you time.
> Rui
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> They should work right away.
>> Do you get any errors in the log files?
>> The preview feature does not always work, because the data extent is
>> sometimes reported incorrectly.
>> Try to create a map, and set the coordinate systems and extent to fit
>> the layer, then add the layer.
>> You should now be able to preview the map.
>> To be certain, try adding a layer with data in the same region that you
>> know works.
>> Rui Daniro skrev:
>>> Hi Kenneth,
>>> Thanks for help, but I believe that is not my problem. As I can see
>>> Paulo problems is to connect to the database, but not my case, I am
>>> able to connect and see the tabular data, the only thing I am not able
>>> to do is plot my geometric data.
>>> Anyway, I did a search on my systems and I could not found those dll's
>>> so I decided copy and past them on the following folder
>>> \MapGuideOpenSource2.0\Server\Bin\FDO . Do they need any customisation?
>>> Rui
>>> *De:* Kenneth Skovhede, GEOGRAF A/S (via Nabble)
>>> [mailto:ml-user+64672-1645459268 at ...
>>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2274344&i=0>]
>>> *Enviada:* 05 February 2009 07:38
>>> *Para:* Rui Daniro
>>> *Assunto:* Re: [mapguide-users] Connect to PostgreSQL database via DNS
>>> (Mapguide Studio 2009)
>>> Hi Rui.
>>> Please see if this explains your trouble:
>>> http://n2.nabble.com/FDO-OGR-Provider-for-PostGreSQL-8.3-%2B-PostGis-td2270066.html
>>> Rui Daniro skrev:
>>>> Hi all,
>>>> I am using MapGuide Studio 2009 and have a database created using
>>> PostgreSQL
>>>> which I connected to it using via DNS. I tested the connection and I
>>> get a
>>>> message saying sucessful connected, then I defined the geometry
>>> properties
>>>> and selected the appropiate coordinate system for the table which I
>>> want to
>>>> map. On preview I can see the geometric properties adn data
>>> properties, when
>>>> I select view data I am able to see my table data, but when I select
>>> view
>>>> feature nothing happens. I can see the zoom/pan tool and the loading
>>>> animation, but nothing happens, I leave it for ages and nothing comes
>>> up.
>>>> Can you help me with this? Can you highlight on this? Thank you in
>>> advance.
>>>> best regards
>>>> Rui
>>> mapguide-users mailing list
>>> mapguide-users at ...
>>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2273611&i=0>
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> This email is a reply to your post @
>>> http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Studio-2009%29-tp2268432p2273611.html
>>> You can reply by email or by visting the link above.
>>> View this message in context: RE: [mapguide-users] Connect to
>>> PostgreSQL database via DNS (Mapguide Studio 2009)
>>> <http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Studio-2009%29-tp2268432p2274344.html>
>>> Sent from the MapGuide Users mailing list archive
>>> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
>>> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090212/c3ca76ec/attachment.html
