[mapguide-users] Custom fusion widget support in MapGuide Studio
Chris Claydon
chris.claydon at autodesk.com
Thu Feb 12 14:04:08 EST 2009
There are several supported parameter types in the widget info, though I don't think they are documented anywhere right now.
Try finding a pre-existing widget that has similar parameters, and look at its widget info file.
Note that the supported types are not very complex, but you should be able to get checkboxes for Booleans, combo boxes for options with a restricted set of values, fields with browse buttons for selecting resource IDs, color pickers for colors etc.
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, February 11, 2009 7:35 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Custom fusion widget support in MapGuide Studio
Hi All,
When I create and register a custom fusion widget, I can see it in the list
of available widgets. But when I edit the widget parameters in MapGuide
Studio, all the parameters are plain text fields. Is this the normal
behaviour?
- Jackie
View this message in context: http://n2.nabble.com/Custom-fusion-widget-support-in-MapGuide-Studio-tp2312828p2312828.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
