[mapguide-users] Regarding Linking of Layers with Map at run time
ravinder.singh at BIRLASOFT.COM
Sat Feb 14 01:03:19 EST 2009
Hi Stefan,
I put the way you said but it gives the following error now.
Type 'OSGeo.MapGuide.MgXmlParserException' in Assembly
'MapGuideDotNetApi, Version=2.0.0.2716, Culture=neutral,
PublicKeyToken=null' is not marked as serializable.
Regards,
Ravinder Singh
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
Dalakov
Sent: Friday, February 13, 2009 11:10 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Regarding Linking of Layers with Map at
run time
Try
MgResourceIdentifier mapName = new MgResourceIdentifier("Session:" +
sessionId + "//Sheboygan.MapDefinition");
Stefan Dalakov
ravinder.singh at BIRLASOFT.COM wrote:
Hi All,
I have created the map definition in maestro and also created a web
layout, and I have hundreds of Maps, and each map will have a single
layer, but I don't want to create the hundreds of maps for each single
layer. For that purpose I though I will just make a single map and will
associate the layer at run time to that map. So I wrote the following
set of code for Sheboygan sample
But when I reach to map.Save(resourceSrvc, mapName)
it gives me the error
MgXmlParserException {"An exception occurred in the XML parser."}
And also I tried with Map.Open and then the following error comes
Resource was not found:
Session:b275c3b6-ffff-ffff-8000-001a4bb4a756_en_7F0000010AFC0AFB0AFA//Sa
mples/Sheboygan/Sheboygan.MapDefinition
I have written the following code
MgUserInformation userInfo = new MgUserInformation(defaultUser,
defaultPassword);
MgSite site = new MgSite();
site.Open(userInfo);
sessionId = site.CreateSession();
MgUserInformation userInfo_new = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo_new);
MgResourceService resourceSrvc =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceSe
rvice);
sessionId + "//Samples/Sheboygan/Sheboygan.MapDefinition");
MgMap map = new MgMap();
map.Open(resourceSrvc, mapName); // Here the problem comes
map.Save(resourceSrvc, mapName); // Here the problem comes
I am using .net aspx with map guide 2.0
Thanks & Regards,
Ravinder Singh
"This message and any attachments are solely for the intended recipient
and may contain Birlasoft confidential or privileged information. If you
are not the intended recipient,any disclosure,copying, use, or
distribution of the information included in this message and any
attachments is
prohibited. If you have received this communication in error, please
notify us by reply e-mail at (administrator at birlasoft.com) and
permanently delete this message and any attachments. Thank you."
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is
prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090214/f224e3c2/attachment.html
