[mapguide-users] pop up window in Ajax viewer
padmini godavarthi godavarthi.padmini at gmail.com
Sat Feb 14 07:12:55 EST 2009
thanks for u r reply.
my actually my requirement is that while selecting each polygon a pop up
window should be open.
1) Is it posible with ur first statement that
 "Is it enough to add a link to the layer, so the user can ctrl+click  to
open?"
2) i didn't get ur second statement .How to use digitizepoint  and how to
perform manually?
Thanks and Regards,
Padmini.
> open?
> Otherwise, you can use the digitizepoint to get the click event,
> and perform everything manually.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> iam using mapguide opensource 2.0 (with .net 2.0 + iis 5.1) with Ajax
>> viewer
>> and using maestro for creating packages.
>> Now i  have a polygon layer (with parcels) now my requirement is that
>> while
>> clicking on one polygon a pop up window should be open.
>> 1) How to do this?
>> can anybody having idea on this
>> Thanks and Regards,
>> Padmini.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/pop-up-window-in-Ajax-viewer-tp2321693p2326014.html
