[mapguide-users] aspx code behind
ed57gmc-bus at yahoo.com ed57gmc-bus at yahoo.com
Sat Feb 14 19:17:46 EST 2009
Thanks, I'll check more into that. I'm new to asp.
Ed Jobe
To: mapguide-users at lists.osgeo.org
Sent: Friday, February 13, 2009 8:33:39 PM
Subject: Re: [mapguide-users] aspx code behind
Yes, asp.net will treat them as HtmlControl (or is it HtmlGenericControl?)
objects on the server-side.
- Jackie
Ed Jobe wrote:
> Can you do that to regular html elements? Don't you have to use asp
> controls?
> Ed Jobe
> From: Jackie Ng <jumpinjackie at gmail.com>
> Sent: Friday, February 13, 2009 4:31:03 AM
> Include a runat="server" attribute in the html element you want to expose.
> Then in the code-behind, either set its relevant properties or its
> Attributes collection property.
> - Jackie
> staniz wrote:
>> I am trying to make default.aspx with code behind.
>> Can sameone helps to provide information of code behind with Mapguide
>> API?
>> default.aspx.cs
>> using OSGeo.MapGuide;
>> public partial class Default2 : System.Web.UI.Page
>>    protected void Page_Load(object sender, EventArgs e)
>>        MapGuideApi.MgInitializeWebTier(@"C:\Program
>> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\webconfig.ini");
>>        MgUserInformation userInfo = new MgUserInformation("Anonymous",
>>        MgSite site = new MgSite();
>>        site.Open(userInfo);
>>        String sessionId = site.CreateSession();
>>        String webLayout = "Library://DevTV/HelloWorld.WebLayout";
>> default.aspx
>> <html xmlns="http://www.w3.org/1999/xhtml" >
>> <head>
>>    <title>HelloWorld</title>
>> </head>
>> <frameset rows="0,*" border="0" framespacing="0">
>>  <frame />
>>  <frame id="ViewerFrame"
>> src="/mapguide2008/mapviewernet/ajaxviewer.aspx?SESSION=sessionId&WEBLAYOUT=webLayout"/>
>> </frameset>
>> </html>
>> How to sent value from code behind to aspx?
>> please help..
>> regards,
>> Staniz
> http://n2.nabble.com/aspx-code-behind-tp2319949p2320957.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/aspx-code-behind-tp2319949p2325214.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090214/f787c9a8/attachment.html
