[mapguide-users] FDO 3.4.0 Beta 1 - SQL 2008 - empty schema
miansi
AndreiSinelnikov at SierraSystems.com
Sun Feb 15 12:09:59 EST 2009
Thank you for the quick reply Kenneth!
Here is what I've got:
<?xml version="1.0" encoding="UTF-8" ?>
<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:fds="http://fdo.osgeo.org/schemas/fds" />
Do I treat it as no schemas? Any idea where to poke next? ;-)
Thank you
Kenneth Skovhede, GEOGRAF A/S wrote:
> On this page:
> http://localhost/mapguide/mapagent/index.html
> Click "Feature", then "DescribeSchema".
> Fill out the "ResourceID" field with the path of your FeatureSource,
> then click "Submit".
> If the result gives no schemas, you have some trouble with the provider.
> If there are schemas in the xml, you have found a Maestro bug.
> If so, please create a trac ticket, and attach the xml to the ticket.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> miansi skrev:
>> Hello,
>> I am trying to use FDO 3.4.0 Beta 1.
>> I have MGOS 2.0.2, I downloaded Windows SDK for FDO 3.4.0 Beta 1. and
>> copied
>> everything from
>> fdosdk-win32-3.4.0_Beta1.tar\Bin
>> directory into
>> C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO
>> I am using MapGuide Maestro v1.0.9.37733 and MapGuide Studio 2008
>> After replacing FDO I was able to create dataconnection to SQL 2008, but
>> then I tried to create layer using this data connection I noticed that
>> schema dropdown is empty:
>> http://n2.nabble.com/file/n2322472/FDO%2B3.4.png
>> No errors in C:\Program Files\MapGuideOpenSource2.0\Server\Logs
>> Do I have to update schemas or do something else to make it working?
>> Thank you
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/FDO-3.4.0-Beta-1---SQL-2008---empty-schema-tp2322472p2330513.html
