[mapguide-users] Properties Value
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Tue Feb 17 14:20:35 EST 2009
Can you change property type to integer using Autodesk Map or FDO tools?
How familiar you are with JavaScript?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of staniz
Sent: Tuesday, February 17, 2009 5:52 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Properties Value
I am using MGE and MG Studio 2008 and have layer and sdf file as polygon
feature type. In my table there is one field, a Property Name =
"Population"
and Property Type = "double", I checked/selected this property in
"Properties displayed in the viewer" check box. when I select the
polygon in
the browser, then in the Properties frame appears
Name Value
1. Population 454.000000 (with 6 additional zeros),
Actually the value for population is 454. How to fix and remove this
additional 6 zeros?
thank for help.
staniz
View this message in context:
http://n2.nabble.com/Properties-Value-tp2341900p2341900.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
