[mapguide-users] Fusion 2.0 Beta Notes
Berdel, Brian
brian.berdel at mcmtrans.com
Tue Feb 17 15:50:20 EST 2009
Actually, I was a little too quick with that email...the measure tool and units are ok in my map..The units weren't set correctly in the AppDef. I will do some further testing before creating tix for the other issues I noticed.
Thanks,
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Tuesday, February 17, 2009 3:34 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion 2.0 Beta Notes
It would be really helpful if these issues can be broken up into
separate tickets and entered into the Fusion Trac system as new tickets
(http://trac.osgeo.org/fusion/)
Cheers,
Mike
Berdel, Brian wrote:
> Hi guys, some of these improvements are great and this version will def be the best yet once.
> I tested in the bundled standard template and I am seeing the same issues as mark described
> Everything is in meters including the measure tool. No Tool-Tips, etc
> Also, Tiled maps only work If I load them from the Map Menu...loading a tiled map as my initial map creates the legend but the map is empty when setting Single Tile = false. However if I load it from the map menu it shows up correctly
> Thanks,
> Brian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark Pendergraft
> Sent: Tuesday, February 17, 2009 12:13 PM
> Subject: RE: [mapguide-users] Fusion 2.0 Beta Notes
> Paul,
> I have been experimenting with both the MapGuide standard template and
> my own.
> Apparently I had a coordinate system issue in my map that I was testing
> (changed it and forgot to change it back), which explains the negative X
> value. Although my map is still reporting in meters despite being in
> feet.
> Still at a loss as to the other issues though.
> -Mark
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer
> Sent: Tuesday, February 17, 2009 4:53 AM
> Thanks for the feedback Mark, we'll try to take a look at these
> issues. Which template are you using, or is it one that you have
> created?
> Paul
> On 16-Feb-09, at 9:17 PM, Mark Pendergraft wrote:
>> I'm trying to implement Google Maps into my Fusion application using
>> the 2.0 Beta. I'm having a bit of trouble. Right now I'm trying to
>> load the Sheboygan map and the google map in the same MapGroup and
>> my program has continuous errors (which seem to point to the
>> maptip). I also have to disable the OverviewMap when I load the
>> google map because it crashes when it loads.
>> Can anyone provide some instructions or a brief overview on how we
>> should be incorporating MapGuide and Google Maps into the same map?
>> Also, I've noticed a few other bugs in 2.0:
>> The CursorPosition widget does not show up in default layout unless
>> the widget is added twice to the Statusbar container. It would
>> appear that the second element in the statusbar container is
>> actually overlapping the first element. So the element is there,
>> but you can't see it because the second element in the container is
>> on top of it. This happens with all Splitterbar controls added to
>> the layout.
>> Neither Tooltips nor the MapTip appear to work.
>> The Coordinates in the CursorPosition widget appear to be
>> incorrect. The X value is always negative (on the Sheboygan example
>> and on my own map which is in Washington State Plane Coordinate
>> System (HPGN) North Zone US Foot). A negative X value in a
>> Washington state projection would indicate a position somewhere in
>> the ocean.
>> Another issue I've noticed with the CursorPosition widget is that it
>> always seems to report in meters despite my map being in Feet. The
>> widget reports in my maps units (feet), but appends a 'm' on the end
>> of the X and Y.
>> Thanks
>> -Mark P.s
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
madair at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
