[mapguide-users] Simple Question Regarding MAP with weblayout
Jackie Ng jumpinjackie at gmail.com
Tue Feb 17 21:38:34 EST 2009
The AJAX viewer only accepts a weblayout (with a valid map definition
reference inside)
What you can do is to get the xml content of the weblayout, replace the map
definition reference with the map definition you want, and then save this
xml into a session-based weblayout, and pass this weblayout to your AJAX
viewer.
Hope that helps.
- Jackie
Jamo wrote:
> Probably been asked before but I can't find the answer through search.
> Is it possible to set the MAP for a weblayout within the URL....?
> Default map for the weblayout definition is PortBris....
> However I would like to change this from the URL .... hopefully it is a
> standard operation ...?
> http://vmapp01/mapguide/mapviewerajax/?WEBLAYOUT=Library://Production/Layouts/Test.WebLayout&LOCALE=en&USERNAME=Anonymous&PASSWORD=&MAPDEFINITION=Library://Production/Maps/PortBrisBH.MapDefinition
> Cheers
View this message in context: http://n2.nabble.com/Simple-Question-Regarding-MAP-with-weblayout-tp2344229p2344640.html
