[mapguide-users] Properties Value
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Wed Feb 18 04:28:42 EST 2009
Hello,
You can directly connect to the SDF file via Map 3D. Just find it in
repository folder under data files.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of staniz
Sent: Wednesday, February 18, 2009 4:40 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Properties Value
Ivan, thanks for suggestion.
I knew that other properties with integer property type were fine.
Should I safe and reload again the sdf file from MG Studio or I can
directly
connect to this internal MGE studio sdf file. I don't have the original
file (maybe it come from .shp file), I just received MGP package file.
I am
still studying Java Script, I wrote some script with JavaScript but not
so
familiar.
thank
Staniz
Ivan Milicevic wrote:
> Can you change property type to integer using Autodesk Map or FDO
tools?
> How familiar you are with JavaScript?
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, February 17, 2009 5:52 PM
> Subject: [mapguide-users] Properties Value
> I am using MGE and MG Studio 2008 and have layer and sdf file as
polygon
> feature type. In my table there is one field, a Property Name =
> "Population"
> and Property Type = "double", I checked/selected this property in
> "Properties displayed in the viewer" check box. when I select the
> polygon in
> the browser, then in the Properties frame appears
> Name Value
> 1. Population 454.000000 (with 6 additional zeros),
> Actually the value for population is 454. How to fix and remove this
> additional 6 zeros?
> thank for help.
> staniz
> http://n2.nabble.com/Properties-Value-tp2341900p2341900.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/Properties-Value-tp2341900p2344887.html
