[mapguide-users] Create programmatically a map
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Wed Feb 18 05:58:25 EST 2009
Can you write pseudo code of your task? What do you want to do? I need
little more information about your problem.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
Sent: Wednesday, February 18, 2009 11:42 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Create programmatically a map
Hi Ivan,
below, you can see my code to create the new map:
Dim resID As New
MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
Dim enc As New System.Text.UTF8Encoding(False)
Dim newMapDef As New MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
enc.GetByteCount(XMLMapTemplate.OuterXml))
newMapDef.SetMimeType(MgMimeType.Xml)
Dim resourceSrvc As MgResourceService =
siteConn.CreateService(MgServiceType.ResourceService)
resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
Dim map As New MgMap()
map.Create(resourceSrvc, resID, MapName)
Then, this is my code to create the map layout:
Dim resID As New
MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
Dim newLayoutDef As New
MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
enc.GetByteCount(XMLLayoutTemplate.OuterXml))
newLayoutDef.SetMimeType(MgMimeType.Xml)
resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
map.Save(resourceSrvc)
Perhaps between map and layout creation I should refresh the mapframe as
suggested from you?
Thanks in advance for your help.
Fabio
Ivan Milicevic wrote:
> Can you provide us code sample?
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Wednesday, February 18, 2009 10:38 AM
> Hi Ivan,
> thanks for your suggestion, but my problem is not to refresh the
viewer
> to
> show the map just created, but is the correct creation of new map and
> layout.
> I think to have found the origin of my problem, but I don't understand
> the
> error:
> Argument is null. Exception occurred in method
> MgWebLayout.ParsePrintCommand
> at line 880 in file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\web\src\webapp\WebLayo
> ut.cpp
> Have you some idea?
> Thanks, Fabio
>> Hello,
>> You can change href of mapFrame. Here is sample code.
>> var mapa = "cijevi"; //defines map name
>> var stringMape = "Library%3a%2f%2fPROJEKTI%2fSUPRANET%2fMAPE%2f" +
> mapa;
>> var hrefMapa =
"http://172.21.10.3/mapguide/mapviewernet/mapframe.aspx?MAPDEFINITION="
>> + stringMape +
".MapDefinition&TYPE=HTML&SHOWLEGEND=0&SHOWPROP=0&INFOWI
DTH=0&LOCALE=en&HLTGT=1&HLTGTNAME=&SHOWSLIDER=0&SESS
>> ION=" + mgSessionId + ";
>> //changing mapFrame href
>> mapFrame.location.href = hrefMapa;
>> Hope this helps.
>> Sent: Wednesday, February 18, 2009 9:57 AM
>> Subject: Re: [mapguide-users] Create programmatically a map
>> Hi Kenneth,
>> I need again your help about my problem.
>> I think the problem is that after new map run-time creation in
library
>> repository, I cannot use its map definition to create its web layout.
>> How can I assign the new map to the layout?
>> Thanks again, Fabio
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> Try to look at the Maestro code:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Lo
>> calNativeConnection.cs#L182
>>> Hopefully you will find a small difference there.
>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> sekko970 skrev:
>>>> Yes, the "OuterXml" property contains the XML header line.
>>>> Fabio
>>>>> Does the "OuterXml" property contain the <? version="1.0"
>>>>> encoding="utf-8" standalone="true" ?> line?
>>>>> sekko970 skrev:
>>>>>> Hi Kenneth, and thanks for your promptly reply.
>>>>>> I had used an ancoding instance.
>>>>>> Below, you can see my code to create the new map:
>>>>>> Dim resID As New
>>>>>> Dim resID As New
Nothing)
>>>>>> Thanks for your help.
>>>>>> Fabio
>>>>>>> You could have the problem that .Net emits an utf-8
>> byte-order-marker
>>>>>>> (BOM), when
>>>>>>> writing xml.
>>>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>>>> To counter this, explicitly create an encoding instance:
>>>>>>> System.Text.Encoding enc = new System.Text.UTF8Encoding(false);
>>>>>>> Then implement a xml writer, or manually convert the xml to
> bytes,
>>>>>>> using
>>>>>>> the encoding.
>>>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a library,
>> even
>>>>>>> for commercial applications,
>>>>>>> and it handles this quirk and others.
>>>>>>> sekko970 skrev:
>>>>>>>> Dear all,
>>>>>>>> I have created programmatically a map (and its layout) using MG
>> .Net
>>>>>>>> web
>>>>>>>> API.
>>>>>>>> After creation, the new map and layout are visible in MG
> Maestro,
>> and
>>>>>>>> using
>>>>>>>> the 'Show in browser" button are correctly shown in browser.
>>>>>>>> The problem happens when I load the map directly from browser,
>> and
>>>>>>>> the
>>>>>>>> following error appears:
>>>>>>>> << The type 'OSGeo.MapGuide.MgNullArgumentException' in
assembly
>>>>>>>> 'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
>>>>>>>> PublicKeyToken=null' is not marked as serializable >>.
>>>>>>>> Then, simply saving the new layout from MG Maestro (without any
>>>>>>>> modification), and reloading the map directly from browser, the
>> error
>>>>>>>> disappears and the map is correctly shown.
>>>>>>>> After saving the layout, there aren't differences in map and
>> layout
>>>>>>>> XML
>>>>>>>> definitions.
>>>>>>>> Have you any idea about?
>>>>>>>> Thank you in advance.
>>>>>>>> Fabio
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.htm
>> l
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345874.htm
> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346122.htm
l
