[mapguide-users] Create programmatically a map
Ivan Milicevic Ivan.Milicevic at supranet.hr
Wed Feb 18 06:12:31 EST 2009
Please, before you open layout and map in Maestro go to:
http://localhost/mapguide/mapagent/index.html -> go to
Resource-->GetResourceContent--> and type correct resource ID on right
side. See is there any strange things in output XML file. Compare it
after saving it in Maestro.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
Sent: Wednesday, February 18, 2009 12:05 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Create programmatically a map
This is my problem:
I have created programmatically a map (and its layout) using MG .Net web
API.
After creation, the new map and layout are visible in MG Maestro, and
using
the 'Show in browser" button are correctly shown in browser.
The problem happens when I load the map directly from browser, and the
following error appears:
<< The type 'OSGeo.MapGuide.MgNullArgumentException' in assembly
'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
PublicKeyToken=null' is not marked as serializable >>.
Then, simply saving the new layout from MG Maestro (without any
modification), and reloading the map directly from browser, the error
disappears and the map is correctly shown.
After saving the layout, there aren't differences in map and layout XML
definitions.
Have you any idea about?
Ivan Milicevic wrote:
> Can you write pseudo code of your task? What do you want to do? I need
> little more information about your problem.
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Wednesday, February 18, 2009 11:42 AM
> Hi Ivan,
> below, you can see my code to create the new map:
> Dim resID As New
> MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
> Dim enc As New System.Text.UTF8Encoding(False)
> Dim newMapDef As New
MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
> enc.GetByteCount(XMLMapTemplate.OuterXml))
> newMapDef.SetMimeType(MgMimeType.Xml)
> Dim resourceSrvc As MgResourceService =
> siteConn.CreateService(MgServiceType.ResourceService)
> resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
> Dim map As New MgMap()
> map.Create(resourceSrvc, resID, MapName)
> Then, this is my code to create the map layout:
> Dim resID As New
> MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
> Dim newLayoutDef As New
> MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
> enc.GetByteCount(XMLLayoutTemplate.OuterXml))
> newLayoutDef.SetMimeType(MgMimeType.Xml)
> resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
> map.Save(resourceSrvc)
> Perhaps between map and layout creation I should refresh the mapframe
as
> suggested from you?
> Thanks in advance for your help.
> Fabio
>> Can you provide us code sample?
>> Sent: Wednesday, February 18, 2009 10:38 AM
>> Hi Ivan,
>> thanks for your suggestion, but my problem is not to refresh the
> viewer
>> to
>> show the map just created, but is the correct creation of new map and
>> layout.
>> I think to have found the origin of my problem, but I don't
understand
>> the
>> error:
>> Argument is null. Exception occurred in method
>> MgWebLayout.ParsePrintCommand
>> at line 880 in file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\web\src\webapp\WebLayo
>> ut.cpp
>> Have you some idea?
>> Thanks, Fabio
>>> Hello,
>>> You can change href of mapFrame. Here is sample code.
>>> var mapa = "cijevi"; //defines map name
>>> var stringMape = "Library%3a%2f%2fPROJEKTI%2fSUPRANET%2fMAPE%2f" +
>> mapa;
>>> var hrefMapa =
"http://172.21.10.3/mapguide/mapviewernet/mapframe.aspx?MAPDEFINITION="
>>> + stringMape +
".MapDefinition&amp;TYPE=HTML&amp;SHOWLEGEND=0&amp;SHOWPROP=0&amp;INFOWI
DTH=0&amp;LOCALE=en&amp;HLTGT=1&amp;HLTGTNAME=&amp;SHOWSLIDER=0&amp;SESS
>>> ION=" + mgSessionId + ";
>>> //changing mapFrame href
>>> mapFrame.location.href = hrefMapa;
>>> Hope this helps.
sekko970
>>> Sent: Wednesday, February 18, 2009 9:57 AM
>>> Subject: Re: [mapguide-users] Create programmatically a map
>>> Hi Kenneth,
>>> I need again your help about my problem.
>>> I think the problem is that after new map run-time creation in
> library
>>> repository, I cannot use its map definition to create its web
layout.
>>> How can I assign the new map to the layout?
>>> Thanks again, Fabio
>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>> Try to look at the Maestro code:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Lo
>>> calNativeConnection.cs#L182
>>>> Hopefully you will find a small difference there.
>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>> sekko970 skrev:
>>>>> Yes, the "OuterXml" property contains the XML header line.
>>>>> Fabio
>>>>>> Does the "OuterXml" property contain the <? version="1.0"
>>>>>> encoding="utf-8" standalone="true" ?> line?
>>>>>> sekko970 skrev:
>>>>>>> Hi Kenneth, and thanks for your promptly reply.
>>>>>>> I had used an ancoding instance.
>>>>>>> Below, you can see my code to create the new map:
>>>>>>> Dim resID As New
>>>>>>> Dim resID As New
> Nothing)
>>>>>>> Thanks for your help.
>>>>>>> Fabio
>>>>>>>> You could have the problem that .Net emits an utf-8
>>> byte-order-marker
>>>>>>>> (BOM), when
>>>>>>>> writing xml.
>>>>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>>>>> To counter this, explicitly create an encoding instance:
>>>>>>>> System.Text.Encoding enc = new System.Text.UTF8Encoding(false);
>>>>>>>> Then implement a xml writer, or manually convert the xml to
>> bytes,
>>>>>>>> using
>>>>>>>> the encoding.
>>>>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a
library,
>>> even
>>>>>>>> for commercial applications,
>>>>>>>> and it handles this quirk and others.
>>>>>>>> sekko970 skrev:
>>>>>>>>> Dear all,
MG
>>> .Net
>>>>>>>>> web
>>>>>>>>> API.
>> Maestro,
>>> and
>>>>>>>>> using
>>> and
>>>>>>>>> the
> assembly
any
the
>>> error
>>> layout
>>>>>>>>> XML
>>>>>>>>> definitions.
>>>>>>>>> Thank you in advance.
>>>>>>>>> Fabio
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.htm
>>> l
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345874.htm
>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346122.htm
> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346216.htm
l
